Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
How to configure Dlink Ap 1665
I cannot access through dlinkap through browser to configure
I bought D-Link HHP-W310AV but cannot access to the setup page when type in dlinkap on my browser. Pls help
Enter http://192.168.0.50 in the address field.
By default, Admin will be the User Name . Leave the password blank.
If you still can not access the web-based configuration utility see the troubleshooting guide on page 48 of the manual located at the below web link.Good luck!
http://www.dlink.com/-/media/Consumer_Products/DHP/DHP%20W310AV/Manual/DHPW310AVA1Manualv100WW.pdf
Dec 21, 2014 | D-Link Computers & Internet
Dlinkap
http://support.dlink.com/emulators/wbr2310/lan.htm
Aug 06, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Bought the D-Link DAP-1360 and my problem is that my laptop does not have a port to take the ethernet cable. How do I set it up nw as a range extender?
You don't need to connect via ethernet. In your laptop set the IP address to 192.168.0.2. subnet 255.255.255.0
This will probably temporarily disconnect you from your internet but you can reset the IP address back later. It might be a good idea to write your current settings down for later.
Open your browser and enter dlinkap or 192.168.0.50
You will connect to the Dlink AP
follow the directions in the user guide found at the link below.
http://global.dlink.com.sg/site_support/DAP-1360/Manual/DAP-1360_Manual_v1.00.pdf
Feb 11, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Mar 09, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I have a Dlink 1150, it dosnt open the page in order to configure the device, when i write the dlinkap text in the box of url. Could any body help me?
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 15, 2011 | Computers & Internet
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Configuring DAP-1150
address to access d-link DAP-1150
http://192.168.0.50
you have to make sure that your ip address is around 192.168.0.xx
Apr 25, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Cannot connect dlink 1150 access point to my HP 550 laptop
go for the default ip address like 192.168.1.1 or 192.168.2.1 or 192.168.0.1 this default ip address you just try to go the router or access point page and then just configure it through the user manual in the CD try it.
Mar 12, 2009 | Computers & Internet
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
