Question about Stanley Bostitch SB1664FN 16 Gauge Straight Finish Nailer
Brand new boost itch finish nailer double shoots or does'it shoot
  • 1388 Answers
SOURCE: nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Posted on Jan 08, 2009
Editor925
  • 285 Answers
SOURCE: sparks from nailer
Do not worry.This is quite normal. It is the metal driver hitting the head of the nail.There are no electrical components in a pneumatic nail gun so this is pure metal-on-metal strike sparks. You may find it is more visible on certain nails than on others. But do not worry. It is normal. You may find the sparks reduce after time as the driver wears a little or takes on a certain shape.
All sounds normal though. Do not worry :)
Please rate this solution on FixYa!
Posted on May 29, 2009
SOURCE: will not shoot a nail
hi you may have a nail jammed in carousel.. unplug and dismantel and locate jammed nail. this happended to me once so this may be your problem
Posted on Oct 14, 2009
  • 65 Answers
SOURCE: f28 ww framinf nailers. 4 relatively new
It sounds like you are using the wring nails. check the recommended nails and the degree of the strips. there is a large variety of degree's available if it is a Bostitch usually 28* is what your looking for. next the gauge of nails need to match and then whether or not they are paper collated or wire. that will cause problems like that all day. hope this helps
Posted on Dec 28, 2009
  • 4234 Answers
SOURCE: I have a SB-1850BN Bostitch finish nailer that no
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Posted on Jan 12, 2010
What causes the finishing nailer to double shoot?
Your air pressure may not be correct. Your nailer should have a recommended pressure and you need a regulator on your air supply to acheive that. Also, do you have the correct nails for your nailer?
Oct 11, 2017 | Air Tools & Compressors
I have a paslode finishing nailer that is occasionally firing. If i jam it hard it will shoot. #902000
You can adjust the settings arm on it to make it shoot out easier look on YouTube it may be there
Jan 22, 2015 | RTO Paslode 902000 IM250 Ii Cordless 16...
Dewalt 16 guage 18 volt finish nailer will not shoot nails
1) Check to see if the drive belt is intact
2) Check and make sure the driver blade is not bent
3) Make sure return device is properly clipped down so the driver can fully retract
If you don't have success, please let me know more details of what the tool is doing and I will try to talk you through it.
Jul 16, 2014 | Dewalt D51256K 16 gauge finish nailer kit
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Why does my paslode f350S shoot one nail, but not shoot the next nail/
Had that problem on one of mine. If it is a multi degree nailer double check your degree setting. It will always shoot the first but will jam on the second.
Feb 15, 2012 | Air Tools & Compressors
Gun doubles, shoots two nails and jams.
Nails are coated and the coating seems to get inside these machines. It needs to be taken apart and cleaned to work properly again
Jan 16, 2010 | Omega Paslode 901000 Impulse Cordless...
Huskey finish nailer shoots twon nails at one
sounds like your nail guide has been damaged or worn try your supplier for a new guide
hope this helps ian
Mar 16, 2009 | Air Tools & Compressors
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch SB1664FN 16 Gauge Straight Finish Nailer Logo
142 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
