Question about Sakar Vivitar 7.1MP ViviCam 1022 Digital Camera - Pink
Cannot open door to replace battery for x022 - Sakar Vivitar 7.1MP ViviCam 1022 Digital Camera - Pink
How do I charge it? theres no room for batteries and it wont charge on my laptop
Seems battery is pre fitted inside Camera, not all Cameras can be charged up on USP port. You then need the Camera battery charger, to charge from the mains
Feb 24, 2015 | Vivitar Vivicam X022 10.1 Megapixel...
Are the battery replaceable? Or do we have to buy a new remote opener?
Yes you change the batteries in a garage door opener remote. You can find on at your local pharmacy. If you have to push the button several times and the batteries don't help you may need to replace the remote.
Feb 10, 2015 | Building Materials
My highlander 2008, the doors can be locked and open with key and remote but cannot open the trunk with key and remote
To make the rear door open, you have to hold the button for a while. If the battery is weak, that will drain the power and the door will not open. Try the other remote and see if it works. At that point, I would replace the batteries in both remotes anyway.
That would be the fastest and cheapest way to eliminate one possible problem.
If the inside open button works to open the door, I would say the mechanism is working fine and it is the batteries.
I had to replace the batteries in both my remotes at the 3 year mark. That should be about now, the second time, for yours.
Dave
Sep 01, 2014 | 2008 Toyota Highlander
I need a replacement of a USB cable for the VitiCam X022
Order it off amazon or the original maker's website.
Jan 20, 2014 | Vivitar Cameras
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Craftsman 1/2 HP Model 139.53914 The wireless outdoor keypad will not open the garage door but it will close it. The two garage door openers work just fine and the indoor keypad works fine. Replaced the...
Sounds like it has lost signal strength and the door cuts it down to the point that the receiver never gets the signal when the door is in the way. If it did that before you replaced the battery then you will have to replace the keypad.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door doesnt work all the time
MAKE SURE YOUR BATTERY CONNECTIONS ARE CLEAN AND TIGHT.
IF YOU HAVE REPLACED THE BATTERY AND REPROGRAMED THE KEYPAD TO THE OPENER YOU PROBABLY HAVE A BAD KEYPAD AND WILL NEED TO REPLACE IT
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad only works when closing door
MANY OF THE NEWER UNITS WILL CLOSE FROM THE KEYPAD WITHOUT PRESSING THE CODE - OR USING THE WRONG CODE.
WHEN YOU REPLACE THE BATTERY YOU MUST REPROGRAM THE KEYLESS TO THE OPENER.
HOPE THIS HELPS
Oct 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sakar Vivitar 7.1MP ViviCam 1022 Digital Camera - Pink Logo
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
