Question about Flotec Plumbing
Check switch of a pedestal flotec sump pump
Water got on pedestal pump when pipe disconnected due to frozen pipe outside. How can I check to see if motor still good or simply switch?
  • 83 Answers
SOURCE: convert a Flotec Flotec FP4012 pump from 110 volts to 240 volts
Here is a link to your manual.
http://www.flotecpump.com/pdf/FP745.pdf
Posted on Mar 30, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
  • 8404 Answers
SOURCE: I have a 3/4 hp FloTec sump pump I bought to
Slow down the water ...
You are probably sucking air. Adjust the switch upward to leave more water in the hole.
Posted on Mar 15, 2010
  • 119 Answers
SOURCE: What value starter capacitor for 1/6 hp Flotec sump
when a motor burns out this will happen , replace the pump.
Posted on Apr 19, 2010
  • 19 Answers
SOURCE: I have a Flotec FPSC1725X-02 Submersible
It's possible that there is a rock or group of rocks that can't get through the impeller and so it will pump for a moment and then the rocks get bound up and block the opening, not allowing water to pass until it is turned off and the rocks have a chance to settle. The only thing you can do is open the case and look for some type of blockage.
Posted on Aug 23, 2010
I purchased a Simer 3986 SS Pump. Need proper mounting location for check valve. I have a manufactured weep hole in the threaded area of the check valve, Pump runs, water level trip vertical float switch...
Thank you for posting your question here on Fixya.com.
The orientation for a sump pump/check valve are the pump is in the bottom of the pit, the discharge pipe leads up into a check valve, usually very close to if not threaded into the pump discharge, and then the pipe continues up and out to wherever your water discharges to. The weep hole needs to be below the check valve.
The hole is there to prevent an air lock in the pump which would prevent it from moving water.
If the water trapped in the vertical run of the discharge pipe is returning to the pit once the pump shuts off the problem is the check valve is not holding or the hole is on the wrong side of the flapper assembly. Did the check valve come with the unit? If not, you will need to fix it if you can or replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Feb 23, 2011 | Flotec SimerOmni 3986 SS Sump Pump
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
All of sudden the sump pump doesn't kick on automatically. I can operate it manually and it works fine.
Same here - I believe I have the same model as you. Not sure how old mine is, since I just moved in.
You may need to replace the switch. I've read that the switch can fail after as little as 2 years on similar models/makes. I'm waiting to hear back from Flotec on the cost of the switch myself.
Dec 26, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
Flotec water pump U27-470. Motor no: S48H2EC11. I ran completely out of water and it wont pump. My tank is full off water noe but it wont syay on and wont pump. If I need to prime how do I do that? I dont...
Your owners manual from Flotec.
You may have an air lock. Disconnect the discharge pipe from the check valve and lift the pump out. Be sure you disconnect the 'bottom' or the check valve so it will still hold any water above it in the pipe. Lift the pump up out of the water and then settle it back into place and reconnect.
You may have damaged the unit by running it dry and lifting it out wont help there. You can try a repair shop but it is usually recommended you replace the whole pump.
Dec 10, 2009 | Plumbing
Water does not come out
you need to bleedthe hose dip one part in water then the other in a bucket with water then it wil start pumping
Oct 31, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
Pump will not shut off.
Checkyour pressure switch. My guess is the pipe that supplies the pressure is clogged. Remove it - blow it out or replace it. Of course, turn off the power first!!!!
Sep 07, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
Flotec 3200a sump pump sensor not working
Check the connections in the float switch (sensor). Give it a bang it may be stuck
Jul 02, 2009 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Flotec Sump Pump Tethered Float - Float seems faulty. Easy fix?
it sounds like it could be a bad float switch but most of the time the water isn't high enough for the pump to turn on. it takes alot of water to turn on a tethered float. the other pumps they sell at lowes with a real float (like the one in the toilet) are adjustable and also replicable. .
Apr 11, 2009 | Flotec Simer//Omni 2957 Submersible Sump...
I have an Simer pedestal pump and the part that connects to the impeller from the motor is broken. I can not find a repair part or part #. Can you help me? THX
there is no repair parts all you can do is change the pump,, go with a submersable zoeller pump best on the market for the price aprox 100,
Mar 15, 2009 | Flotec 1/3 Horsepower Economy Pedestal...
Plumbing Logo
27 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
