Question about TurboChef Ovens
Toaster oven hinge
What parts do I need to replace the left hinge on my turbochef high speed toaster oven.
SOURCE: Turbochef Oven Repair
turbochef has its own service called turboservice you can go to there website under contacts us and there you find a tel #
Posted on Dec 20, 2007
SOURCE: Hinge snapped on Nardi EK95583AC Range cooker
I have the same problem and am about to replace both hinges and hinge runners (http://shop.ukwhitegoods.co.uk) recommend you should replace both hinges as if one is gone the other will follow soon. The section on the hinge gives a good account on how to replace the hinges safely and how to get to the runners that may need getting into the inside of the oven by removing the sides. I havent gone through this yet so cannot honestly give any more advice other than whats out on the web.
If you follow this link please:
http://tinyurl.com/djntxb
The parts you need are listed there for you. Part numbers 031118009907R and 031199009903R
Adamski
Posted on May 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
  • 75 Answers
SOURCE: turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Posted on Jan 28, 2010
  • 75 Answers
SOURCE: I have NGC tornado Turbochef, it is toasting too
the subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
How to replace thermocouple on turbochef toaster
take top cover off. It's about in the center. install a new one. pretty simple part to change. of course always unplug oven first.
Jun 04, 2014 | TurboChef TORNADO Electric Oven
Turbochef tornado toaster wont get to menu, just warming up
The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
Feb 13, 2013 | TurboChef TORNADO Electric Oven
Our Subway Turbochef Toaster has a keypad issue.
check pad connections if all good you need new pad
Dec 01, 2011 | TurboChef TORNADO Electric Oven
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
Jul 14, 2010 | TurboChef C3 Single Oven
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
Dec 12, 2009 | TurboChef TORNADO Electric Oven
F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
Dec 21, 2008 | TurboChef TORNADO Electric Oven
What I need to know to change the hinges on a Turbochef Tornado
Hello. Yes I was going to say, it should be hardest to take the covers off, than anything to replace the hinges. Easier to replace the right one if you take a few items out of the way, and move/disconnect some wiring. Just unplug is the biggest thing, should be ok after that. Guess you figured it out by yourself though. Congratulations :)
Dec 08, 2008 | TurboChef TORNADO Electric Oven
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Nov 15, 2008 | TurboChef TORNADO Electric Oven
Ovens Logo
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
