Question about Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher
Code a11 shows - Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher
..Fusible Link What gauge wire do I need to use for the main fusible link in a 2000 jeep cherokee?
my guess he means , what thermal wire code to use.
they are color coded.
the fuse is bottom M1/M2 location of the PDC right"?
the problem is the OP failed to show exact wire.
my guess this is PDC question, (where are your hands/?)
fuse link A11? gas engine, right, USA?
A11 code 10 DG (dark green)
to the generator?
caused by shorted ALT or changing it with battery connected
yes, they blow.
the they have not just one engine, nor one alternator
but 124 amps the alt on 4L , with automatic. 4speed.
these are the rules. SAE.ORG
What size replacement fusible link should be used ?
The automotive service industry recommends using the same gauge and length as the blown fusible link after the cause of failure is corrected.
guide lines,
A 14-gauge wire would be protected by an 18-gauge fusible link. A 6-gauge wire would be protected by a 10-gauge link, and so on. Odd number wire gauge sizes like 19, 15, 13 and 11 are counted when sizing a link. The length of a fusible link should not exceed 9".
is the old link, still readable.
see the color
measure its size,. these tow question are first.
my jeep FSM shows it as 10 gage harness size. (M1/M2 gen slot)
so, 8 gauge thermal link is my guess. per SAE.
why not go to jeep and buy it?
Jan 05, 2017 | 2000 Jeep Cherokee
Andrews maxiflo water heater code a11
A11 is a slaveboard lockout code- Flow Temperature: Flow temperature went above 95C.
This is the manual. http://www.andrewswaterheaters.co.uk/download.php?doc_id=378
Feb 03, 2014 | Water Heaters
2 WIRES PULLED OUT OF THE PLUG ON BACK OF ALTERNATOR ONE WHITE WTH RED STRIPE ONE BLACK WTH WHITE STRIPE WHICH ONE IS IN THE CENTER
dont guess.
ouch, the FSM shows all connector pin outs in the rear.
you never said the year.
nor country diff, countries have different harness colors.??????
my 04' FSM shows.
2 wires. (not counting case and big wire)
the 2 plug. called A11 plug.
a11 pin 2 white red. charge lamp.
a11 pin1 black white,,, IG fuse.
but where are the, page 9a-16 shows that.
harness side,
key up, locking key up
1, 2 , X ( x is blank socket pin) left to right.
1 blk-wh
2 whit red,
or go to alldata dot com and look.
Sep 22, 2013 | Suzuki XL7 Cars & Trucks
Data copy san disk .but anather computer connect not show data
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
An example on how to safe documents , photo's or data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope it helps
Oct 24, 2012 | SanDisk SDCZ50-032G-A11 32GB Cruzer Blade...
My laptop is Toshiba Dynabook Satelite A11 from japan. But vga driver not found. pls help me
Try to search in the internet the driver of your Toshiba Dynabook Satellite A11. There is a lot of driver there.
Jul 15, 2011 | Computers & Internet
Webcam camera driver for toshiba tecra a11
http://www.google.com/url?sa=t&source=web&cd=1&sqi=2&ved=0CBwQFjAA&url=http%3A%2F%2Fdriver-toshiba.blogspot.com%2F2010%2F04%2Ftoshiba-tecra-a11-drivers-for-windows-7.html&rct=j&q=toshiba%20tecra%20a11%20drivers&ei=CAzyTZL9Fsic-wbUy4TGAw&usg=AFQjCNFM7Y2Ilo27YDDagHCoYoovrIk93g&sig2=tOyBkj44XHMccMQx_ItaaQ&cad=rja
Jun 10, 2011 | Computers & Internet
Need help finding fuseible link that goes to starter
CHARGING SYSTEM
The charging system is an integral part of the battery and starter systems. Since all of these systems work together, any diagnosis and testing should be done in conjunction.
The charging system is protected by a 12 gauge fusible link located in the A11 circuit. This fusible link is between the generator and the starter.
The generator ground is provided through a case ground in the generator to its attaching bracket. This generator uses a voltage regulator internal to the Powertrain Control Module (PCM)
When the vehicle is running, battery voltage is applied to the generator field terminal through the A142 circuit. This circuit is the output from the contact side of the Automatic Shut Down (ASD) relay. The ground, or voltage regulated side, of the generator field is controlled by the K20 circuit which connects to cavity 4 of the PCM connector.
When there is current present in the field, and the rotor is turning, the stator in the generator produces a B+ voltage that is supplied to the battery through the A11 and A0 circuits. The A11 circuit is connected to the output terminal of the generator and connects to the engine starter motor battery feed terminal. The A0 circuit is a direct feed line from the battery and connects to the engine starter motor.
Grounding for the system is accomplished at the battery negative terminal. These grounds connect to the engine and body.
HELPFUL INFORMATION
Inspect for a blown fusible link in the A11 circuit between the generator and the starter motor.
other Fusible link goes from the starter to the alternator. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 11, 2010 | 2004 Dodge Neon
A11 Fault
A 11 is a heater problem. It is given a certain amount of time to reach the proper temp then the fault code A 11 comes on. The heat element may not be working. If you select no heat (if available) it may not show the fault.
Apr 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher Logo
Top Hotpoint-Ariston Dishwashers Experts
Antonio Santacruz
Antonio Santacruz
Kelley Jones
Kelley Jones
Level 1 Expert
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
