Question about Apple iPad Tablets & eReaders
Display not starting
At staring no display on
  • 34 Answers
Connect to PC and start iTunes. Select the ipad and see if that helps.
Posted on Apr 12, 2014
Display and backlight using my battery up how do I fix this?
The display and backlight are the biggest users of power for any computing device. You can lower the display brightness and on some even lower the backlight intensity to conserve power, but this will have an impact on your viewability.
Sep 18, 2016 | Tablets & eReaders
Tip
Calibrating The Tablet Pc Pen
Although it may be tempting to open the box and start playing with your <b>Tablet PC</b>, one of the most important things you should do is calibrate your pen. This means spending time with the pen after a few steps to ensure that the tablet PC pen knows the touch screen is used. To do this, click Start, and the parameters of the search field type <b>Tablet PC</b>. On the list of results Tablet PC Settings and from there go to <b>Display </b>&gt; <b>Display Options</b> &gt; <b>Calibrate</b>.Follow the steps to finish the door and remember to save your settings to accept calibration.<br />
on May 07, 2011 | Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Tablet wont stay on
Check the display settings and the power settings.
The display.
You can set for 5 minutes the default is usually 30 seconds.
The power settings.
Make sure it is not in savings mode an turns off the display very quickly.
Some battery savers reset the display.
Even other programs will reset things you had no idea.
Remember to read the information packet before loading apps.
Good luck these are the most common Tablet issues.
Apr 08, 2015 | Tablets & eReaders
Bauhn 9.7 3g tablet will not start up
Many things can cause a tablet fail to start. A damaged battery is one. It can also be due to a burned display. More often than not, it is due to OS having been corrupted. If the tablet can start with the charger connected, chances are the battery is no good and had to be replaced. For defective display, you can try connecting the tablet to a digital TV through the HDMI port. You may see something if the tablet is working but its display is defective. If the OS is corrupted, you will have to reflash its ROM with the right version using a computer. This process is a little too technical for novice. Get help from an expert. Remember, flashing will void your warranty.
There are other less likely causes for startup problem. If it's hardware issue, you are doomed.
Jan 12, 2015 | Tablets & eReaders
Display Colors
use the warranty..you paid for it...
Feb 02, 2014 | Proscan 7-Inch Android Internet Tablet,...
Asus tf101 only half screen showing
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Jun 22, 2012 | ASUS Eee Pad TF101B1 Tablet
My Toshiba Portege R200-S2031 LCD display has developed lines across top and RH side of screen. What kind of fix is there?
First, give the screen a good cleaning using a microfiber cloth. This may inadvertently remove the lines even though they are in the display.
If this doesn't work, you'll have to send the laptop back for repairs. Screens are not a component that can be replaced easily (such as RAM or a hard drive).
If your laptop is not under warranty, scope out some local computer shops that can replace the display for you. Make sure to ask them for a quote BEFORE they do work on your computer, otherwise they have the right to deny you your laptop, once they fix it, until you pay up (a possibly very nasty price).
Mar 30, 2010 | Toshiba Portege R200-60 12.1 XGA LCD...
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
My display is not working well
Not displaying well?...change the resolution to highest setting in display properties!
Feb 12, 2008 | Toshiba Satellite R25-S3503 Tablet PC
Tablets & eReaders Logo
16 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
