Question about Power Probe 3 Combo Kit with Gold Test Lead Set
The reset button does not reset the unit - Power Probe 3 Combo Kit with Gold Test Lead Set
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
How can i reset my coby tablet
Aug 20, 2011 | Coby Kyros 716829701508 Tablet PC
Need to reset to factory settings
Try this hard reset method:
  • With the unit powered on, press and hold the reset button on back of unit for 30 seconds
  • Without releasing the reset button, unplug the unit and hold reset for another 30 seconds
  • Plug the unit back in STILL holding the reset button a final 30 seconds
Aug 16, 2011 | Linksys WRT160N Wireless Router
No signal- from my wireless route can not clear arp cahe Linksys sat my wrt54g is old
Perform a 30/30/30 reset; aka Hard Reset.
Hard Reset (aka 30/30/30 reset): The following procedure will clear out the NVRAM and set dd-wrt back to default values:
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments,...
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Dec 28, 2010 | Sharp Cell Phones
I lost the web key number how else can i retrieve it?
You can't retrieve it but you can try to reset it:
-With the unit powered on, press and hold the reset button on back of unit for 30 seconds -Without releasing the reset button, unplug the unit and hold reset for another 30 seconds -Plug the unit back in STILL holding the reset button for another 30 seconds
This shall give you a total of 90 seconds.
Your modem will restore its default settings
Aug 20, 2009 | Computers & Internet
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I can not turn on my 530 and it dos not show that the battery is being charged on the screen
Yes, there is a way to reset it. You can try the reset button under the faceplate, or a Master Reset. Keep in mind, a Master Reset WILL ERASE ALL OF YOUR FAVORITES. In order to do a Master Reset the unit must be off. Press and hold the bottom right of the screen, then press the on button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts. To use the reset button, you must remove the faceplate carefully (put your fingernail or another object in the indentation on the top of the faceplate, and pull it toward you). Then press the reset button on the right hand side of the unit.
Mar 02, 2008 | GPS
Power Probe 3 Combo Kit with Gold Test Lead Set Logo
67 people viewed this question
Top Power Probe Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Power Probe Measuring Tool and Sensor Expert? Answer questions, earn points and help others
