Bosch Classixx 5 (WAA12165ME)
I have an issue with Bosch Classixx 5 (WAA12165ME). It worked fine for a few years but now it's not automatically programmed. I would turn the knob to 40 to the left (cotton and linen). There are three status indicators. The first one is wash. The light would on for more than one hour and it doesn't go up to the second indicator, rinse. Frustrating! I would have to manually turn the knob to rinse then it would automatically move on to spin and end the wash. Also, the washing machine is no longer making water warm. It washes clothes with cold water! Please help. Thanks!
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
SOURCE: Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Posted on Feb 16, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
F 21 appears on panel
Hi, This sounds like the motor brushes need replacing, but its possible that the machines control circuitry has been upset by mains surges or spikes, so try the following to reset the machine first....
1. Turn the appliance knob to the off or reset position, (12 o'clock)
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button & while holding it, turn the knob to the 7 o'clock position, keep holding the spin button and then release it after about 5 seconds, now turn the appliance knob back to off.
Hopefully when you turn the machine back on it will have reset the error and you can continue to use the machine.
If the machine goes back to F21 after a program has been started then it is most likely the motor brushes need replacing or you have a faulty motor drive module.
Hope this helps
Midge.
Feb 13, 2011 | Bosch Classixx WFL 2066 Front Load Washer
F:21 error displayed
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Press and hold the spin button.
Whilst holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
To reset it.
While holding it, turn the knob to the 7 o'clock position.
Release the button.
Nov 27, 2010 | Bosch Washing Machines
Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Mar 10, 2010 | Bosch Classixx WFO 2866 Front Load Washer
How to wash clothes in bosch classixx 5
I will be very happy to assist you in this issue.
follow this web to learn more about your washer
http://www.onino.co.uk/washing_machines/bosch_classixx_wfl_2066.html
i hope this answer your question
your rating and comment its very important to me
thank you
Nov 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Nov 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
