Question about Frigidaire Dryers
Heat not on airflow clogged all other operations functioning correctly
No heat, drum, and blow all working effectively. Error code is FLO E5B 002
4 Suggested Answers
djz83
  • 88 Answers
SOURCE: Kenmore dryer does not heat up. Mod#110 60912990
First I would make sure that you have 240volts coming into the dryer. Then I would check the thermal cut-off in is a fuse on the housing of the element. that should be it but if not look for the heater relay.
Posted on Jan 13, 2009
  • 1891 Answers
SOURCE: How can you test the safety thermostat?
safty fuse may just be a bad one . to ck thermo use a tempt tester in the vent . it chould cycle at 155 deg on hi and 140 on del .settings. if flex venting is used it may have been kinked . if yo don't tust the thermo the you should change it .. but keep in mind it takes 190deg + tempt to blow the saftey..
Posted on Dec 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: affinity aeq7000eeo e5b 006 error code
Probably a stuck button Use this SERVICE manual to locate your tech sheet and it will give you info on errors for your particula machine
Posted on Aug 31, 2012
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
May 19, 2015 | Frigidaire Dryers
It is hot. And the harddrive was recently put back in the computer . What does that mean. Thera gota b a crash code to just redo everything. Its a hp laptop. Windows 8.1 which i officialy hate
The title says HP laptops. It is a laptop or a desktop PC? You said it was hot. Heat is the enemy of all electronics. Resetting won't solve anything until you figure out why the unit is getting hot. Laptops, contrary to their name, should never be held on your lap. They need airflow which is pulled in from fans on the bottom. Operating them on your lap, on a bed, on a sofa, or on any soft surface blocks the airflow and causes heating. Also, fabric surfaces introduce dirt, hair, and lint into the cooling system which can clog the heat exchanger and cause overheating. Have the laptop checked to ensure the cooling fans are running and that there is proper airflow. Clean the cooling system if necessary. If this is a desktop PC, there are similar issues. Many people place tower units in computer desks that have doors on them and operate them behind the closed door. This causes poor airflow. They also place them on floors and they will suck up lots of dust and dirt that will clog the cooling fins of the CPU hear exchanger. Check the CPU fan and heatsink and ensure that the cooling fins are not clogged. DO NOT remove the heatsink to clean it. Get a can of Electronics duster (canned air. Use this to blow the dist and dirt out of the clogged fins. Once you have the heat issue fixed, then worry about the reload/reset. Yes, if the machine came installed with Win 8.1, it probably has a recovery partition you can use to restore the PC to factory settings.
Mar 18, 2015 | HP Computers & Internet
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
Drum wont turn, Do I need a belt?
If motor turning, belt slip, bearing could be broken. It's not easy to change the bearing, but first try spin the drum, if it can spin freely, then tighten the belt tensioner by adjusting the motor mounting screw.
Oct 07, 2014 | Kenmore HE2 Plus Front Load Washer
Code 157
Error code 157 on your vehicle indicates a problem with your mass airflow sensor. The mass airflow sensor gives a reading based on the air intake and output within the engine compartment. A properly functioning sensor will contribute to better fuel economy. In some instances, you may be able to clean your mass airflow sensor to clear the error code, but the error will most likely return in a short time. Fortunately, replacing the mass airflow sensor is a reasonably simple repair.
Read more: How to Correct Engine Code 157 ' eHow.com http://www.ehow.com/how_7982654_correct-engine-code-157.html#ixzz2IH5Ki64X
Jan 17, 2013 | Ford Windstar Cars & Trucks
Affinity aeq7000eeo e5b 006 error code
Aug 30, 2012 | Electrolux Dryers
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Error code E00012-002
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Feb 19, 2009 | Canon imageRUNNER 2200
Dryers Logo
14 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
