Question about GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12...
Ge beverage center doesn't cool - GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12...
2 Suggested Answers
  • 46460 Answers
SOURCE: monogram beverage center model # ZDBC240NBS. Where can I get a wiring diagram and service manual?
perhaps the manufacturer but most will not give their service manuals out to the general public .
Posted on Feb 15, 2016
Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Feb 15, 2016 | Refrigerators
Monogram beverage center model # ZDBC240NBS. Where can I get a wiring diagram and service manual?
Feb 15, 2016 | GE Refrigerators
Can the evaporator be replaced in a model ZDBC240NABS ge monogram beverage center
Sorry, there is no evaporator listed in the parts breakdown. Only the items in the compressor area.
Feb 22, 2015 | GE Refrigerators
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
My GE zdbc240nbs recently stopped cooling and the compressor felt very hot, so I replaced the compressor start relay, overload relay and capacitor. It is still not cooling but compressor runs. Any thoughts
The first thing to check is if you have the proper amount of refrigerant in the system, which requires special tools, at the very least a gauge set. You need to know the level of refrigerant is correct before replacing any more parts.
Aug 02, 2013 | GE ZDBC240NBS Beverage Cooler
Monogram zdbc240 frost inside doesn't shut off
First thing to check is the condenser here is a diagram to show you the condenser, it is #75 on the diagram you want to make sure the coils are free and clear of any dust and dirt that would stop good air flow, this would be one reason the unit would run continuously. Let me know if it is clean.
Nov 18, 2012 | GE Monogram ZDBN240NBS Stainless Steel...
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
I just bought a brand new Frigidaire 4.6 cu beverage center FFBC46F5LS, brought it home and plugged it in. Ran it overnight and still at room temperature. I can hear the motor is on, light is on. not...
Being it is brand new you should contact Frigidaire about getting it repaired or replaced under warranty.
Frigidaire 1 (800) 374-4432
Monday - Sunday
8:00 am - 8:00 pm (EST)
Aug 03, 2011 | Frigidaire PLKU1267DS Stainless Steel...
GE Monogram ZDBN240NBS Stainless Steel Beverage Center, Beverage Shelf on Full-Extension Slides, 12... Logo
21 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
