Question about Sony MHC-GX450 CD Shelf System
Hello the red light to my stereo keeps blinking but when i try to turn on my stereo it will not go on the red light just continues to blink please help me fix this problem?
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Posted on Nov 13, 2007
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
I have a red signal light that keeps blinking in gp328 any ideas?
A blinking red light can be a sign of the radio picking up radio frequency waves (RF) on your same frequency or a nearby frequency. There may something transmitting in your area which is causing the blinking light, or you may have another radio which could be stuck in transmit. One way to check this is to take the radio to a different location and see if the blinking still occurs.
Next, the question would be, does the radio function otherwise correctly? If so, continue to use the radio and do not concern yourself with the light. If the radio does not function properly, they you should send it to a qualified radio repair center for service.
Best regards.
Sep 17, 2014 | Radio Communications
The light blinks red continuously on my kdf55e2000 sony tv
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
Nov 01, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
Panasonic projection tv pt 53 wx 42 f wont turn on and blinks red continuously?
3 blinks or 5 blinks and pause are most common on this set---try to watch and count the blinks and let me know which you find
Dec 12, 2012 | Panasonic Televison & Video
Stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
May 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Red light on top off phone keeps flashing. i would like to know how to turn it off. tks. for your help
Have you tried taking the battery out and putting it back in? It may free it up. On the other hand, I have a corded phone that blinks when there is a new call with caller id. If I don't scroll down to every call, it continues blinking. If you have caller id, just scroll down a little more and see if the blinking stops.
hold the page button down for 5 seconds, that usually clears the blinking beep/light!!!
also make sure no old messages are in the VM inbox!
Apr 11, 2011 | Uniden 5.8GHz Dual Cordless Phone
My palm centro will not turn on the red light just blinks and occationally it does come on
Hello abevagota25,
A flashing red indicator light (upper left-hand corner) occurs when the Centro is connecting to the the cell phone network. The light will continue to blink until it gets a strong enough signal to make a good connection. Try turning the phone on from different locations to see which one makes a good connection
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
Feb 02, 2010 | Palm Treo 500 Centro
Red light keeps blinking when I try and take a picture
actually the flash ckt is having problem that is the reason the red indicater blinks. you can take photographs with flash off mode,to solve this problem you will have to contact service centre
Dec 08, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Se-d1 will not boot
escient music server...light blinking red...
cant turn on system...
tried resetting...nothing
tried turning system off..for a hour or two...nothing..
juse blinks will not respond to anything...
any ideas.
Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
Hello my name is mariah
here is what i found on amazon. i will let you know if i have sucess.
4 of 4 people found the following review helpful: stars-3-0._v47082372_.gif Easy fix for GX250, June 11, 2006 By J. Petrosky - See all my reviews
c7y_badge_rn_1._v47060296_.gif I recently repaired a GX250 that refused to turn on (flashing power led), and apparently this fix works for most other problems too, including "no disc" errors and no sound output.
What you need to do is clean and reseat the (widest) white ribbon connector that connects the front panel to the large circuit board on the side. To get to the connector, you'll have to take off the sides and the top, and then unscrew the cd tray so you can lift it up and get your arm and hand in far enough to reach the connector from the opposite side. Then unplug the ribbon cable, blow the connector out with some compressed air, and plug it back in firmly.
Oct 27, 2007 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 CD Shelf System Logo
574 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
