Question about Siemens Washing Machines
Error code e18 keeps appearing - Siemens Washing Machines
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 03, 2009
SOURCE: E18 error code keeps showing up. The camera won't shut off.
check out the below link to know what ur error means and how to fix it
http://www.e18error.com/
thank you have a nice day
Posted on May 11, 2009
  • 321 Answers
SOURCE: i keep getting an E18 error and i can't take
Hi; this code appears when pressure is apply on the lens assembly and surrounding try to hold your cam
with out touching lens block or apply pressure arround / so now you gone try to reset that by put it
off and on until the code disappear and if not try by removing all battery in / if that not works you may needs service to fix back your lens block;
hope that will help you
have a nice day...
Posted on Mar 05, 2010
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Camera will not switch on/off properly, and "E18" appears on the screen
"E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 06, 2010 | Canon PowerShot A95 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
I keep getting an E18 error and i can't take
have a nice day...
Mar 05, 2010 | Canon PowerShot S2 IS Digital Camera
Fault code e18
Camera lens must have taken an impact, Because that error code means zoom lens error Have to unjam lens. Has to be done by a repair shop/person. A lot of labor to take apart, TC
Aug 31, 2009 | Canon PowerShot A70 Digital Camera
May 11, 2009 | Cameras
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Canon powershot A60. When the camera is turned on there is no image won't take shots, has a number on screen E18 and shuts down after a few seconds. Mike
E18 is an error code from self diagnostic system of the camera.if there is a malfunction in the lense assembly or the focus assembly then this error code appears. You have t show it at a repair shop.
Jul 17, 2008 | Cameras
Problem with E18
The "E18" error code indicates an error that involves the lens unit or lens cover. Or it may appear if you apply pressure to the area surrounding the lens while handling the camera. Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it
Oct 02, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Washing Machines Logo
77 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
