Question about Sony MDS-JE440 Mini Disc Player
Recording backing tracks from computer
Can i record from a computer to my mini disc if so what cables do i need
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
Standard audio cables or optical cables or coax cables.
Posted on Nov 25, 2014
dvdcdlaser
  • 1285 Answers
SOURCE: Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Posted on May 25, 2009
HW_Dude
  • 87 Answers
SOURCE: How do i record from my mini disc player onto my
Have a look here this seems one way of doing this
Posted on Oct 24, 2009
TOLhamRadio
  • 509 Answers
SOURCE: jb 940 md player. Recording a full disc, always
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Posted on Nov 06, 2009
  • 189 Answers
SOURCE: Giving
HELLO
Strange one this! C13 is a protection error, but the machine should play discs that it recorded. It could be that you may have to give the laser lens a good cleaning by using a cotton bud and a little isopropyl alcohol. You will have to remove the cover to do this and when you clean the lens use a gentle circular motion.
Don't soak the cotton bud when you do this but if you do, remove any excess liquid. Leave it for about 5-10 minutes then try the machine again.
If there is no change, then you will have to take it to a service centre in your area.
GOOD LUCK!
Posted on Apr 25, 2010
eliezerpenny
  • 236 Answers
SOURCE: The recording level on my mds-je480 seems to be restricted
First of all, the remote has nothing to do with anything. Neither does the PEAK HOLD function.
Apparently, your source is not putting out a lot of signal. Check to see if it has a volume control. Or that you are connected to the right output (line level and not headphone out, for instance).
Of course, you can always turn up the recording volume on the 480. That's what it is there for. You can go up 12dB, which is plenty. And you can turn that up with the remote or with the AMS dial.
Posted on Jan 17, 2012
Why doesn't it record to md?
You can't make a copy of a copy of a digitally recorded MiniDisc, so make sure that isn't what's happening- if so, it usually says "Din Unlock" and you can't record. I think when I record from one deck to the other digitally, I have set the recording deck to "REC", then I hit 'play' on both decks at the same time. Using the digital input, it should automatically set your track marks. You cannot make a digital copy of this MiniDisc, BUT you can make an Analog copy. Let me know if you need more info.
Dec 11, 2015 | Audio Players & Recorders
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Mini disk player JES510 want to record some midi tracks using the optical link. keeps saying din unlock & then if try says cannot record. How can I overcome this? Help appreciated.
Like most home recorders the minidisc will not let you make digital copies of a digital original. The idea is to prevent piracy of copyrighted material.
Unfortunately, that includes digital tracks you yourself made,
Just go through the analog inputs. It will sound fine.
PS - professional minidisc recorders will let you record digitally, but they are expensive.
Mar 11, 2011 | Sony MDS-JE480 Mini Disc Player
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
Strange recording problem - no diagnostic messages
Sounds like the servo is shot on the deck that moves the laser. MDS JE520 is a nice early deck 1998-1999 vintage, so it's had a great run and I'd look for another on eBay or at a "hamfest" swap & shop for parts.
Mar 26, 2010 | Sony MDS-JE520 Mini Disc Player
Record on to mini disc
you can use optical cable / or mini plug to (Y) RCA jacks ...plug the optical cable to the back of a CD player or RCA jacks to your Reciever / Amp (output) to record
Aug 25, 2009 | Sony Net MD Walkman MZ-N505
How to put song in the disc of mini disc amplifier?
You need a mini disc recorder to load songs to the disc. it's similar to burning a cdrw disc in your computer.I have a Pioneer PMD-R55-S portable mini disc recorder which been use once or twice and then stored back to its original box for years. if interested $ 160 + 6pcs new blank disc free. you can contact me at chaoyoc@gmail.com
Aug 15, 2009 | Kenwood KMD-673R MiniDisc Player
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Sony MDS-JE440 Mini Disc Player Logo
182 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
