Question about NetGear N300 Wireless Router
How do I configure netgear N300(WNR2000) router with BSNL teracom type 1 modem. Currently I am using internet by connecting modem and laptop with cable. Detailed instructions would be helpful! Thanks.
  • NetGear Master
  • 2,219 Answers
Ask your ISP.
Posted on Mar 08, 2015
redhaze89
  • 854 Answers
SOURCE: Myh new Netgear WNR2000 won't connect to my cable
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 11, 2009
  • 27 Answers
SOURCE: Problems connecting with a Netgear WNR2000
your easiest solution is probably just to reset everything back to defualt settings. there is a small pin hole button on the back or bottom to do this.
hope this helps!
Posted on Aug 24, 2009
anandg27
  • 1272 Answers
SOURCE: PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Posted on Sep 06, 2009
SOURCE: Can't obtain IP - Net Gear WNR2000 router
Try to open the Router page using "ROUTERLOGIN.COM" in IE and go to WAN Setup option in which u can see Disable SPI Firewall (check the box), also reduce the MTU Size to 1400 or 1390
Posted on Sep 16, 2009
Geekman
  • 32281 Answers
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii
.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Dec 20, 2009
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
Belkin 2100 modem wifi bsnl
I would ask your service provider if that modem is on the compatibility list.
Jan 26, 2013 | Belkin N Wireless Modem-Router F5D8633au4A
Netgear n300 will not connect to internet
There should be a little red button that you can push. It is the reset button. Hold it down for around 10 seconds, and try again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/randall_17db19439e8e78e3
Jul 04, 2012 | NetGear N300 Wireless Router
How do I password protect my NETGEAR N300 WNR2000 from outside connection?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 16, 2012 | NetGear N300 Wireless Router
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Hiee I am using netgear N300 jwnr2000 router. The router worked fine for few days it has suddenly stooped working.Any of my wierless devices are not able to detect my router since the wifi in been...
Unplug both your DSL/Cable Modem, and the Router from power. Wait 30 seconds. Plug in power to DSL/Cable Modem only, and wait for it to connect. then plug in power to Router, and wait for it to start up. Give it about 1 min. If the lights are still not on, you may need to reconfigure your router. If this does not work, connect your cable/DSL modem to your computer directly, and power cycle it again. Once it is online, check to see if you can get online, if you cannot, contact your internet service provider, as you have ruled out a problem with the router.
Dec 28, 2010 | NetGear WNR2000 Wireless Router
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
NetGear N300 Wireless Router Logo
104 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
