Question about Sony MHC-GX450 CD Shelf System
Hello my name is mariah
My stereo the red light keeps blinking but when i go to turn it on it will not go on the red light only continues to blink can you please help me ?
Re: hello my name is mariah
Here is what i found on amazon. i will let you know if i have sucess.
4 of 4 people found the following review helpful: stars-3-0._v47082372_.gif Easy fix for GX250, June 11, 2006 By J. Petrosky - See all my reviews
c7y_badge_rn_1._v47060296_.gif I recently repaired a GX250 that refused to turn on (flashing power led), and apparently this fix works for most other problems too, including "no disc" errors and no sound output.
What you need to do is clean and reseat the (widest) white ribbon connector that connects the front panel to the large circuit board on the side. To get to the connector, you'll have to take off the sides and the top, and then unscrew the cd tray so you can lift it up and get your arm and hand in far enough to reach the connector from the opposite side. Then unplug the ribbon cable, blow the connector out with some compressed air, and plug it back in firmly.
Posted on Feb 14, 2008
0 characters
3 Points
Timer red light blinking
You will need to use the remote to re set your system
Feb 06, 2014 | Sharp XL-HP500 CD Shelf System
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
Sony gnz888d stanby bulb is blinking
Check the back of the stereo to make sure none of the speaker wires are shorted, if okay! it is one or two audio output ic's that are shorted causing the protection circuits to activate to prevent further damage.
May 01, 2012 | Sony Audio Shelf Systems
When i turn on the power it cuts off&the red light startes to blink
there are so many reasons for this matter.better to contact qualified service Technician
Jun 14, 2011 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
How do I set the time
  • Use the actual stereo to set the clock, not the remote.
  1. Turn off the stereo.
  2. Press "clock/timer" for at least 2 seconds.
  3. Press "memory" to make the hours blink.
  4. Turn the volume knob to adjust the hours.
  5. Press "memory" to make the minutes blink.
  6. Turn the volume knob to adjust the minutes.
  7. Press memory.
  8. Now the clock setting is complete.
Regards, Tony
May 21, 2011 | Sanyo AWM-660 CD Shelf System
So I connected 8 speakers to this system and I might have blown it out. when i connect it the red standby light comes on. then when i press the power button the screen goes blank as if turning on but...
Audio output shorted out or blown fuses in power supply check all fuses if fuses are good your Audio out put transitors or I.C has been shorted out as a result of impedence over load in future dont connect speakers in parallel in those small Audio units.
Natureisland technician
Commonwealth of Dominica
Nov 06, 2010 | Sony CMT-HP7 CD Shelf System
I turn the stereo on and it turns off and then the power button starts blinking
i turn the stereo on and it turns off and then the power button starts blinking
Sep 04, 2010 | Sony 560W 5-Disc Mini Hi-Fi Stereo System...
Sony hcd gx450 blinking problem
your speaker are hooked up wrong.or there may be dust in or on the terminals.i used a q-tip with rubbing alcohol and wiped them down.hook up the speaker cords properly and try this again.if this does not work then unplug the stereo and let it sit overnight and try again.
Dec 04, 2008 | Audio Shelf Systems
Stereo won't play
only use original speaker, check cable circuits..
Oct 31, 2008 | Sony MHC-GX8800 CD Shelf System
Un Plug It for like 10 to 20 seconds and plug it in it should work it happens to me all the time if it contionuls check the speaker wires and see if the wires are toching together that will be the problem to
Oct 27, 2007 | Sony MHC-GX450 CD Shelf System
Sony MHC-GX450 CD Shelf System Logo
897 people viewed this question
Top Sony Audio Shelf Systems Experts
Are you a Sony Audio Shelf System Expert? Answer questions, earn points and help others
