Question about Sony FV120 Microphone
I have connected it to my laptop but it doesn't work
Connecting VGA Screen to HDMI laptop
Press and Hold "Fn" and then press number key with "square / square w/ legs (like monitor)" icons
Jun 18, 2013 | Computers & Internet
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
Keyboard doesn't work
Try connecting an USB keyboard to your Acer laptop. If the external USB keyboard does not work the the laptop is faulty.
If the USB keyboard works then reseat the laptop's keyboard connector to the motherboard, it may have become loose.
Mar 02, 2012 | Acer Computers & Internet
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
Cant connect Verizon Wireless Router
Hi! Try to restart your router. If it doesn't work, try to restart your computer. If it still doesn't work, make sure that you don't have a power on/off for wireless on your laptop. If you have that button, turn it on/off and wait to see for a reaction from the laptop. If nothing happens, try to check the laptop's conectivity to other wireless devices. I hope this will work! Have a nice day!
Sep 02, 2011 | Sylvania G-Netbook
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
I have a n5030 dell inspiron and i use to connect using wifi. The last time that i did use my laptop the wifi device is not working (the system says that there is no wifi & bluetooth devices). I use...
Make sure your wifi switch is turned on. If that doesn't work, try taking out the battery of your laptop, waiting at least 10 seconds, and then rebooting. If THAT doesn't work, try system restore and take it back until before your wifi quit working.
Aug 22, 2011 | Computers & Internet
Doesn┬┤t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Sony FV120 Microphone Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
