Question about Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics)
Replacement mirror Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics)
2 Suggested Answers
ana_maria768
  • 3 Answers
SOURCE: broken mirror for 10021
buy another one
Posted on Dec 14, 2012
I have a foil like material on my outside rear
this sounds like the reflective material of the mirror coming off the glass. take it to a glass/mirror shop and see if they can just repair/replace the mirror glass with new reflective material.
Sep 02, 2014 | Cars & Trucks
2004 pacifica
best consider a new mirror as the water will have damaged the reflective finish inside.
Aug 26, 2013 | Cars & Trucks
I need to replace the three globes in the the miirror, I have shopped around cannot find any. HomMedics Mirror model M1702
You will need a Phillips screwdriver(star), flat screwdriver and a hammer. Unscrew the three screws off the side of the mirror with the Phillips. With the flat screwdriver and hammer GENTLY tap all around, until it comes apart. Replace the bulbs,(if you have nightlights you are not using, those bulbs works just fine.) Set the base back on, aligning the openings onto the grooves and secure with screws.
Sep 07, 2011 | Homedics M-7021 Spa Reflectives...
Need to replace right side mirror with new unit. How to remove old unit?
you will need to remove the inner door panel to get to the nuts on the inside of the door panel to remove the mirror.if its just the mirror that is broken(reflective)then a glass place can replace the reflective part by gluing a new one onto the old housing.
May 09, 2011 | Pontiac G8 Cars & Trucks
My mirror broke in a kdf-50we655 and i need to know what the size is so i can order it?
First off the mirror in your Sony is not a standard mirror. It's called a "front or first surface" mirror meaning the reflective surface is on top of the clear glass as compared to normal mirror which has the reflective coating behind the glass.The wrong glass will throw the focus off and reduce the brightness...how much I really can't say. Because of this cleaning the mirror is also very tricky...no alcohol or windex. Use an eyeglass lens type cleaning cloth with a light touch. As for the mirror size...try measuring the mirror mounting or "holding clips" area to determine the original size. Another trick may be to ask your local Sony repair center about the mirror size because they will most likely be your only source to order the correct replacement mirror.
Oct 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sliding mirror door. The mirror is falling off.
No frame around the outside edge of the panels? You can buy glue especially designed for adhering mirrors to a backing. This mirror glue will not pull the reflective material off of the back of the mirror. But it sounds to me like the backing panel may have been compromised whereby it is now warped. So you can try the mirror glue but I am optimistic as to its effectiveness. As an option: buy a high quality roll of tape; cloth tapes come in colors; use the tape as a decorative border which at the same time will somewhat secure the mirror to the backing. Or just replace the mirror doors with new ones; probably cost less than $50.
Apr 23, 2010 | Home
Donnelly 012017 rear-view mirror on 2000 regal
Have to buy a new mirror or:
I was able to avoid buying a new mirror, but my mirror also became so foggy that it was unusable. This correction will not allow the Auto Dimm feature to work!!!!!!! But at least the mirror will function as a mirror. This took me about an 1 1/2 hours (glue needs to dry).
1) Take the mirror off the windshield
metal lever held mine in place
mirror then slides off
disconnect wires
2) Pull the mirror apart
it's glued together
Don't brake the plastic
3) Seperate front glass from the auto dim element
a clear front glass is sandwiched to the
element with a series (or piano style)
of metal clamps
the element is a reflective surface
the clear glass may brake, this is OK
it will not be reused, Be Careful Not
To Cut Yourself
Don't damage the reflective element, though
4) Clean the surface of the element
Be Careful Here, the element scratches
more easily than the glass surface would
have
5) Disconnect the 2 wire connector connected
to the element circuit
this is just a safety step to prevent the
element from trying to work and possibly
heating up
6) Put everything back together
glue the mirror back together
reconnect the mirror wiring if you
need to (my mirror had the compass
that needs power)
put it back on the windshield
I performed this repair about 6 months ago and have not had any problems. The element is the reflective surface that the mirror already used, so it reflects as it should. The auto dim feature, as stated before, does not work, but I didn't have to pay a couple hundred bucks for a new mirror or a used one that would eventually do the same thing. Their is a gap from the plastic edge of the mirror to the element the width of the clear glass that was removed. It is not noticeable to anyone but you.
Nov 02, 2008 | 1998 Buick Century
2000 Buick Regal rear view mirror. Only the center of the auto dim mirror dims now.
I had the same problem. My mirror has map lights so I disconnected the wiring harness from the mirror. I had trouble getting this done, but there is a small clip you must pull back to release the wiring. Once I had the mirror free the button that you must glue back on the windshield is attached to the mirror by a strong metal spring clip. I placed a screw driver under the button and popped it out of the clip. Make sure you mark the outside of the windshield first before you clean off the old glue so you will know where to glue it back. I just placed a small piece of duct tape on the outside windshield. MAKE SURE YOU GLUE THE BUTTON ON CORRECTLY, so the mirror will slide back on. I let the new glue dry for several hours before I tired to re-attach the mirror. The directions said 15 minutes, but that is not long enough. I also sprayed the clip with some WD-40 so it would slide on the button easier.
Hope this helps
Sep 25, 2008 | 1998 Buick Regal
Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics) Logo
60 people viewed this question
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
