Question about Whirlpool duet Washing Machines
I turn my washer on it being a whirlpool model# wtw4800xq1 once I turn it on an it fills up it will not do nothing else,I've tried to advance the dial to other setting to atleast get it to drain an it does nothing...I can hear a very quiet humming noise but it does nothing else,Can anyone tell me what my problem is ?
mikedurland
  • 481 Answers
SOURCE: Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Posted on Jul 14, 2008
SOURCE: Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Posted on Nov 02, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
  • 1937 Answers
SOURCE: Kenmore washer model 110.24422300 fills, but
First, see the Sears Parts Site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24422300
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Nov 30, 2009
I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all hoses...no clog. The water will drain through the pump when the unit is unplugged. Is there a way
it sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Nov 10, 2014 | Washing Machines
Sm8280867
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
Kenmore,Top load, series70 agitates in all Wash positions around dial. Dial advances as it should, then stops, will not pump water out. will not spin when dial is advanced .Fills, agitates,stops.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 29, 2010 | Kenmore Washing Machines
Whirlpool LLR7144DQ0top load. Replaced coupler, now nothing works
Check list:
Motor plugged back in
capacitor reconnected
lidswitch reconnected
timer connection secure
water level hose is not pinched
She oughta take off
Service manual for direct drive and more videos
May 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The washing machine will not fill with water.
this depends on the make of the washer / some whirlpool and kenmore will fill but if the lid switch is bad it will not advance to start washing ,,,, put the dial on spin and with it turned on close the lid and if it dont start spinning then your lid switch is your problem ,,,, can help better if i can have the make, model and serial off your washer.
Larry
Nov 24, 2008 | Washing Machines
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
