Intellowasher wd 8090fb error
Hie, i have one lg intellowasher wd 8089fb and when I turn starts working and after 1 minute at most 5E error appears .. What will it be? can help me?
  • 88 Answers
SOURCE: Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
Posted on Mar 28, 2010
  • 343 Answers
SOURCE: Hi i need an instruction manual for an LG
If you google the brand and model you will get a lot of info and/or a locality where you can request a manual....Good luck.........Nomess
Posted on Apr 21, 2010
  • 713 Answers
SOURCE: lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
Posted on May 13, 2010
beltronic205
  • 1474 Answers
SOURCE: My LG intellowasher 7kg WD-8015C
Most common,Water supply okay, Door closed properly,Child lock not switched on....? Good Luck
Posted on Feb 16, 2011
carlwoermann
SOURCE: LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Posted on May 22, 2012
I've got a LG Intellowasher WD-1023C and it spins real slowly or not at all and there is a glow from the bottom, it also stops with 9 minutes left on the 30 minute wash
a glow does not sound good. any error codes. glowing sounds like a hot/shorted wire, maybe the heating element. i think i would unplug and call for professional service.
Oct 25, 2016 | LG Washing Machines
Temp lights flashing LG intellowasher WD 80100tp
it appears the diagnostic computer has found a problem with the water inlet servos and may need replacing contact LG for replacement parts
Jul 29, 2016 | LG Washing Machines
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Lg intellowasher wd-8013f is very noisy
May 09, 2010 | Washing Machines
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
