Question about Kohler Plumbing
Kohle double facet kithen faucets is leaking - Kohler Plumbing
2 Suggested Answers
  • 297 Answers
SOURCE: mixet single control shower facet leak
did you replace the seats and springs too? if not this may fix your problem.
Posted on Jul 22, 2009
Water is coming into the house but isn't coming out of my facets.
A couple of things to check also:
1. I am assuming that you have checked the shut off valve that is usually inside the garage. Make sure that the valve handle is aligned with the pipe, if not turn the handle so it will be aligned with the pipe.
2. Toilet, flush it and see if the tank is filled up again. if the tank fills up right away, then your problem will be in the faucets.
3. Test your shower. If water comes out of the shower heads, then your problem might be in the faucets.
4. How old id the house? if the faucets are not being used regular basis, your seals in the faucets might have hardened up and sticking.
5. hope I have given you some help in trouble shooting your water problem. Good luck.
Mar 13, 2017 | Plumbing
Fixing a leaking faucet. remove cartridge?
Depends on the type but usually on a double handle facet take the handles off use an adjustable wench and turn counter clockwise. Sometimes it is very hard to turn you can use a pair of vise grips and lightly tap them with a hammer.
Nov 16, 2016 | Plumbing
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Delta 18 series tub facet leaks
the possible cartridges you can replace are listed on this pdf
http://www.deltafaucet.com/media/SpecSheet/DSP-B-R18000_Rev_A.pdf
Jan 13, 2013 | Delta Innovations 18 Series Monitor...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Mixet single control shower facet leak
May 28, 2009 | American Standard 2385.003.002 Reliant...
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Grohe kitchen facet 33 759 clogged
check the airraider on the spout of your faucet it unscrews and can build up with junk and sadly some times sediment works its way in to your faucet and clogs the stems and with a grohe faucet being as pricey as they can be i sugest replaceing the stem as aposed to getting another grohe faucet
Mar 28, 2009 | Plumbing
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Leaking Delta bathroom facet
Is this single handle?If so, you need a allen wrench to take handle okk.But come to think about it you get the tools with the repair kit.
Mar 13, 2009 | Plumbing
Plumbing Logo
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
