Question about White Sewing 955 Mechanical Sewing Machine
When sewing, the the thread, needle does not hook on to the bottowm ( bobbin)
When sewing the bottom tread does not hook on to the top treading
5 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bargainbox
  • 1388 Answers
SOURCE: How do I tread the top of the White - Model 1750?
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. HERE
Posted on Sep 10, 2009
SOURCE: Toyota RS2000, problems with shuttle hook
my suggestion is to have it checked, sometimes sewing thick fabric on some machines can cause a problem.
Posted on Jul 31, 2010
  • 79 Answers
SOURCE: My problem is between the needle and the bobbin.
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Posted on Sep 26, 2011
Singer 9960. my tread wont catch the bob tread
check and adjust needle thread tension tighter
check needle /hook timing
Feb 22, 2018 | Singer Sewing Machines
When the needle is not pulling the bottom tread
is this the first time you use a sewing machine? if you are very familiar with the way the thread is pulled out of the bottom spool, I'd say you need a technician, here is how to install bottom spool in case you don't know. after filling spool, pull thread out through the small gap on the side of the spool holder, then holding the small arm on the holder outward insert the spool holder in to the socket and release after fully inserted. after that the thread should come out the top by manually turning the machine to lower needle
Dec 24, 2014 | Sewing Machines
Bobbin not turn
the hook should rotate to hook the loop and complete the stitch around the bobbin thread.
Feb 26, 2014 | Sewing Machines
My singer 4423 wont pick up the bobin tread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
if these suggestion don't help,,then the machine needs to be
checked by a sewing machine technican to see if it's out of time
Jul 31, 2012 | Singer 4423 Sewing Machine
I have an husqvarna Viking mega quilter18x8 with the imperial frame. I am having problems with the tension and the tread keeps breakingms with. The tension and the tread keeps breaking. HELP!!
If the thread breaks at the needle and is feeding smoothly from the spool, you may have the tension too high. It is impossible to say what the setting should be because the knob rotates all the way around several times. Loosen it off until you see needle thread pull to the back of the quilt, then tighten until it just balances the interlocking of the stitch in the fabric. Test with little swirls, that's most likely to pull needle thread to back.Also, check that the needle is properly installed and that the hook to needle timing and clearance are good.Nesting of thread underneath usually happens if the foot lifter is left up or the tread is not fully in the disks of the tension unit.
Oct 25, 2011 | Husqvarna Viking 1
The fabric is being ruined by the feeder under the fabric. It is not the needle.
It could be different things, the tread may not be locked in the top tension, you may have treads all wrapped up around the bottom bobbin. Take out the bobbin and look, re-thread the entire machine.
May 08, 2010 | Sewing Machines
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
Apr 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Won't sew
you have tread in the bottom of it. and needs a cleaning. check the tension, most set on 3
Dec 15, 2007 | Kenmore 12102
White Sewing 955 Mechanical Sewing Machine Logo
27 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
