Question about Golds Gym Exercise & Fitness
Burning electronic smell
Fan works, screen lights up but controls do not work. Started to make a burning smell after 6 months using the 7.5 volt adapter instead of the 5 - 1.5 volt batteries
  • 96 Answers
SOURCE: Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Posted on Jul 12, 2008
aborcass
  • 2651 Answers
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
rickzilla
  • 706 Answers
SOURCE: burning wire smell
Hello jvtmad1,
All of the previous comments are relatively good ideas but let me offer some additional advice,
First off, You need to determine if the burning smell is coming from the Microwave itself or from the receptacle that provides power to it. Most wall receptacles are rated for 15 amps and should easily handle your microwave ovens power requirements. A simple check might be to run a hair dryer on the same receptacle without the microwave plugged into it. They draw comparable power so that should eliminate the recptacle as the culpret, On the assumption that the burnt wire smell is coming from the microwave itself, then your best bet is to return it to the store for a repair or replacement. Unless you are properly trained on how to sservice that, you probably shouldn't attempt it. As stated in previous comments, it should still be under warranty. If you have a bad filament transformer, magnetron or the wiring between them, that is not something you want to fiddle with yourself.
In summary, eliminate the receptacle on the wall as being the problem first.
If you find tha your receptacle is the problem, then you may be able to remove or disable power to it by switching off teh appropriate circuit breaker or fuse.. then take off the face plate and check the integrity of the wires going to that receptacle and making sure they are tightly secured to the terminals of the receptacle. I would assume that if that were the problem, you would notice a burnt smell as soon as you took off the face plate. Hope some of thes ideas help you resolve your problem...
Regards,
Rick
Posted on Nov 22, 2008
SOURCE: motor has a burning smell
ok from your given data its clear that the problem is with the fan motor..........
i think its because of over voltage problem ( merly because of voltage fluctations )
i want to know one thing are you getting the same problem with all the devices ....??
then please contact theelectricity department.....
Posted on Feb 01, 2009
  • 389 Answers
SOURCE: Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Posted on Mar 01, 2009
Car heater blowing cold air and rubber burnning
If your heater is spraying a light mist through your vents it could be your heater coil. Mine did the same thing, smell rubber burning, then started a light mist through the vents. If you don't get that checked out, it could mess up your water pump and possibly your engine
Jun 22, 2014 | 2000 Chevrolet Cavalier
1998 Buick Century w/ manual control, smelled burning odor and blower motor quit working. Control Module?
blower resistor is common to burn causeing smell. check with dealer, there may be a campain on this problem. if not. replace resistor and harness (pig tail) and blower motor..
Jan 21, 2013 | 1998 Buick Century
Need to know if the cooling fan on a millermatic200 should be on constantly if not when should it come on
Oil the bushings on the cooling fan with a light oil, I use SAE 20W synthetic nondetergent oil- The fan should be running all the time. It provides the 24 volts for the control circuit and contactors.
What you smell burning is likely the insulation on the wire of the fan motor.
Jan 25, 2012 | Welding Tools
Starter and wiring
maybe burning smell is comes from the starter,i think the magnetic field of the starter is burned,check it
Feb 19, 2010 | 2003 Mitsubishi Eclipse Spyder
Burning smell on right side (facing tv)
contact a repairer ur wire inside tv has burnt
Sep 03, 2009 | Philips 30PW8420 TV
Motor has a burning smell
Jan 25, 2009 | Dryers
Burning smell
.. any heat element like bulb must be installed exactly and that means its wattage, voltage and physical characteristics.. and also make sure that you have replaced Fan blowers and making it sure that it runs properly when the unit is on. as it was said also make sure that you do check the light that travels thru lenses and filters that is not block by dirt, cables or any other foreign materials.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Exercise & Fitness Logo
77 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
