Question about Samsung HL-S4266W 42" HDTV
Samsung s4266w take out bulb back cover switch
3 Suggested Answers
SOURCE: how to replace replace fan no.2 on Samsung HL-S4266w? how to re
tack out engine take out lamp take of lamp housing assembly replace fan
Posted on Apr 26, 2010
Ecollier2012
  • 3459 Answers
SOURCE: samsung model hl-s4266w.. I can
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jan 14, 2011
Samsung tv keeps turning off
I had this problem. It cut off and front panel lights were blinking. Replaced bulb with a phillips OME bulb. Part # is on TV. Cost was about $100.
Aug 25, 2011 | Samsung HL-S4266W 42" HDTV
Spots developing on picture
If you are seeing white dots on the screen, that indicates the DMD chip has failed. Samsung will cover the cost to repair this problem if you call 1-800-samsung.
May 21, 2010 | Samsung HL-S4266W 42" HDTV
How to replace replace fan no.2 on Samsung HL-S4266w? how to re
Apr 20, 2010 | Samsung HL-S4266W 42" HDTV
Where is door for lamp located for replacement?
Hi,Here's a video that will guide you through to find where your lamp is located http://www.youtube.com/watch?v=0jr_9A5Xd2Q You can find your original Philips lamp BP9601472A here: http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173 Have a bless one!
Apr 08, 2010 | Samsung HL-S4266W 42" HDTV
Our Samsung HL-S4266w has noise issues.
sound like you have a colorwheel issue. it needs to be replaced
Mar 21, 2010 | Samsung HL-S4266W 42" HDTV
Hl-s4266w Powers on for about 15 seconds then turns off. Was told it is a timer that needs to be turned off by using factory remote - I have lost the remote! now what?
Not sure about the timer. Our 55" samsung broke last week and it was shutting on/off no picture just turn on music recycling off/on. The blue light was lite on TV and red light to the right was blinking. The TV repair guy replace the Power Supply board b/c of swollen capacitors, was under warranty. The board runs about 70 bucks though. Took him all of 5 mins after unscrewing the back cover of TV. The board is at the bottom center after cover is removed. Hope this helps
Mar 18, 2010 | Samsung HL-S4266W 42" HDTV
I HAVE A SAMSUNG HL-S4266W, THE BRIGHTNESS HAS WENT OUT, WHAT COULD THE PROBLEM BE?
usually indicates that the lamp needs replacing or the mirror and cover glass are dusty. the lamp is something you can do yourself.
Oct 29, 2009 | Samsung HL-S4266W 42" HDTV
Samsung 42 plasma ps42q97hdxixeu has power to it but no sound no picture and a clicking noise at the top of the back(like its trying to switch on? 2 yr old
Check the relay you might have a bad relay board. Also check other things like decoder board. I am sure you might have a stuck relay. its hard to tell behind email.
Sep 22, 2009 | Samsung HL-S4266W 42" HDTV
Samsung HL-S4266W 42" HDTV Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
