Question about LG LRE30453ST (Electric) Stainless Steel Range
How to resolve PF issue on LG Electric Range - LG LRE30453ST (Electric) Stainless Steel Range
Kitchaid electric range display PF what to do
PF indicates a Power Failure. Turn off the power supply (for 30 seconds or more) to the unit and then back on, select/touch the range cancel/clear pad and reset the clock. The range should work again, unless there was damage to the control during the power interruption.
Oct 05, 2014 | KitchenAid KERS807SSS - Freestanding...
What to do when PF shows on the electric panel?
the term PF means POWER FAILURE,try powering the oven down at the circuit breaker for 30 minutes to clear the computer,and during this power down check all connections to the control board,then re-power it back up,if this doesn't help then replace the control board
May 13, 2012 | Dryers
What does the code PF mean?
Code PF means at some point the stove lost electrical power, PF=Power failure detected, this can be the wall plug lost power or it can be the control board inside the range failing.
Sep 25, 2011 | Whirlpool RF368LXKS Electric Kitchen Range
WHAT IS PF CODE ON A ELECTRIC STOVE
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
ll;l;[]
Aug 09, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
What does pf display on stove mean
POWER FAILURE.
Your electric may have gone off.
The breaker may have been turned off and back on.
The range may have been unplugged and plugged back in.
You have loose wires in the range.
You have a defective control board.
One of the above will cause a PF code.
Jul 11, 2010 | Whirlpool RF364 Electric Kitchen Range
What does F7 error mean? It is self cleaning, blue interior with bottom warming tray
Hi
Thanks for using FixYa. Error F7 on your LG means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | LG LRE30451 Electric Kitchen Range
Oven repeatedly shuts off and "PF" appears on digital screen- Kenmore gas range. We have never used the self- cleaning option for the oven.
The code being displayed denotes "PF" for Power Failure. It could be that you have a loose connection at either the range connection in back or at the outlet where the range is plugged in. You could even have a loose wire on the breaker in your electric panel.
First, shut off the breaker to your range and then you can pull it out from the cabinet and remove the access panel on the rear of the range. Check the nuts that hold the cord terminals onto the power tabs in the range. They should be tight and clean, without corrosion or any broken strands.
Now, with the power still off at the breaker panel, check the range outlet at the floor or wall. Remove the cover screw and look at the connections to make sure they are tight and secure as well.
Sometimes Aluminum service wires are used and the connections can become "glazed" which can cause a high resistance connection. The wire should have been abraded with a wire brush and an oxide inhibitor added to prevent aluminum oxides from forming on the wire strands and the electric terminals. If yours is Aluminum, you might wish to add an oxide inhibitor to these connection points to make a better electrical connection.
After that, reinstall the cover and plug the range back in, put the range back into place and go to the electric breaker panel and carefully check the wires going to the breaker to make sure they are secure and tight. You'll need to remove the panel cover to get at the breaker screw connections, so care is needed when doing this.
Once you've done these steps, you can put everything back together and turn the power back on and see if it resolves your issue.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
LG LRE30453ST (Electric) Stainless Steel Range Logo
21 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
