Iomega rdhd c2
Hard drive randomly started making a clicking noise and now will not connect with my mac? What should I do?
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Posted on Feb 08, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
bob_computer
  • 3153 Answers
SOURCE: my iomega hard drive won't be reconized by my mac
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 03, 2009
Testimonial: "Great tips, I've done some of these steps in previous issues. Thank you, I have already fixed the drive using the disk utility. "
SOURCE: Iomega terrabyte drive MDHD10T-U2 does not mount, ticking noise
I followed richiegrier solution above - my drive began clicking and did not run. I determined both drives worked and that it was the power supply (apparantly I'm not the only one with this problem. I purchased a NexstarMX dual HDD enclosure. I opened it, flipped the switch up to the JBOD mode, and installedd my two drives. Initially the configuration recognized a single 900+ GB drive, which was empty. I used the safely remove hardware icon, powered down the unit, and switched the positions of the drives - VOILA!!! the computer recognized the drives and all the files are back online, precisely. A couple caveats - the drives when in JBOD mode are A and B, although there is no obvious way to tell them apart - Like a book, A appears to have the directory for the combined drive. When mounted in reverse, the computer did not read the directory, and assumed it was empty. When I reversed the drives, my drive came up, flawlessly with no input from me. THANK YOU. Do not format or create a new partition or you will lose data. I also purchased a 2 TB drive for back up, and will immediately begin a second copy of all the data on this drive so I do not have a disaster. Thanks again for saving me from disaster.
Posted on Apr 01, 2010
lock123
  • 6831 Answers
SOURCE: Western Digital 120GB Hard drive clicking and not reading
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
Iomega rdhd c2
Yes. Search for a program called partition magic, or hard drive partitioning software.
Feb 22, 2014 | Computers & Internet
Iomega rdhd c2
to repartition you will lose all information on hard drive.
copy to another hard drive format to repartition then, then reload data back on.
Iomega rdhd c2
if u repartition ur hard drive all over again the date will lose but if u want repartition part of it and not all u can keep ur data by keeping them in the partition that will remain
My wife and I bought an Apple mac computer just over 3 years ago, and as we wanted to store our large collection of CDs on i-Tunes on an external hard-drive and not on the Mac computer drive, we bought an...
no --there are no engineers at fixya site
from your description the aux hard drive has failed
Most hard drives using discs are good for around 3 years max and then the bushes and bearings fail
If that is the case then you will have to find a repair shop that has the capability to remove the disc from the hard drive and recover all that you have saved
if it as what I have suggested then consider this
There are hard drives (SSHD) on the market that use solid state technology and do not have spinning discs that fail over time
The cost is around $60.00 per gig of storage
best if you take it to a computer repair shop for a proper diagnosis and while there discuss the SSHD technology to prevent failures in future
Feb 27, 2017 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
Trying to find manuals how to use the iomega with my apple mac but are not sure which one i have. On the hard-drive it says iomega with an i above it.
Manuals are not the easiest to come by for Iomega hard drives, but I can certainly assist you with formatting your hard drive for your Mac
All you need to do is this:
font.f1 {font: 14.0px Times}  * From your desktop click anywhere on a blank space on your desktop.
*Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the drop-down menu. This will take you to your Utilities folder.
* Locate and launch the Disk Utility application
* Once Disk Utility is open, with your Iomega drive hooked up to your Mac and turned on, look in the left side bar and you should see your hard drive.
* Click on the hard drive and this will make the right window available to you.
* Now click the Partition tab
* It is here that can change your volume scheme from Current to 1 partition (or more).
* Once you have done that make sure to give your hard drive a name.
* Under Format: Make sure to select "Mac OS Extended(Journaled) format (this is the readable format for a hard drive being used on Macs).
* Once you are satisfied that the partition(s) is configured to your liking, the click Options button.
* Select GUID Partition Table for Bootability on an Intel Mac computer or notebook
*or select Apple Partition Map for a Power PC based Mac computer or notebook.
• Click Ok for that selection
• Click the Partition button and your drive will be ready to use once the format completes.
This should do the trick. Let me know if it works for you.
Thanks!
-Mactechtrainer
Jan 20, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
