Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Hp presario f600 boots and runs but screen wont cut on
  • 3 Answers
Well if you are sure the computer is running, then you could have a bad inverter, take a flashlight and shine it on the screen, if you see the icons and computer booting, then you have a bad inverter, go on amazon and order another LCD. also if you have a desk top monitor, connect the monitor to your laptop, then boot up your laptop, hold down the "FN" (function) button and press "F4", you should see everything on your desktop monitor. Good luck.
Posted on May 07, 2014
Presario 2500 screen wont come on but computer and lites are working
If you can't see any obvious damage, like a cracked screen, sometimes the module that illuminates the LCD screen just goes out. If it has a VGA port and you can get a computer monitor, plug the monitor in and see if it will boot up and run. It is possible that you might have the computer set up to boot to an external screen, but you would still see the Windows and HP logos at the boot up. If you see NOTHING at all, then try an external monitor. If that works, you may replace your screen...or not.
Aug 12, 2013 | Compaq Presario CQ62238DX Laptop
HP Compaq Presario V3000 PC Notebook - Screen Blank, Won't Boot
try to put the windows installer, and re-install again your OS.. format the drive and install a fresh copy of windoes..
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
Blank screen/white screen
Plug in a monitor to the VGA connector on the side. The white screen usually indicates a failed inverter. By using an external monitor you will cut down the likely causes.
Apr 30, 2013 | HP Compaq for Presario V3000 Motherboard
How to open compaq presario sr1420nx computer
You have a virus in your computer. Boot the computer, immediately hit the delete key until you can get to the setup screen and it will allow you to format your drive.
Nov 28, 2012 | HP Compaq Presario SR1420nx...
Compaq presario cq70 wont boot up
old Compaq (now HP)
https://h30434.www3.hp.com/
first screen died, now wont boot, to external VGA monitors.
Fn+F4, sure. the external command key. sure
ok VISTA, first time any one tells what OS is there, wow.
step one on all PCs lap or desk top is what,
does the screen show any text at all?
like Hit Esc to enter setup or BIOS>
we first see of BIOS is alive. it not the PC is DEAD.
zero text means DEAD PC> and NO BIOS means DEAD PC
so out comes that old useless LT battery.
useless as in , if its original its bad. most are.
you skipped step 1 here, (battery out)
and next fans work? and blow air, no lint packups. inside.
learn that PC's go dead, with overheat, can happen fast.
http://pcdied.com/black-screen.html#Laptop
Jun 28, 2017 | Compaq Computers & Internet
Compaq Presario F600 Can power on but lcd screen is black. Help
Bad motherboard. Just went through this with mine.
Jan 27, 2010 | Compaq Presario Notebook
Screen is black, but fan runs. Then computer cuts
This most often means you have a bad cpu or motherboard. When the bios does its post checks it looks for issues and will shut the pc down if all the devices are not funtioning correctly or the CPU reaches critical heat.
Dec 29, 2009 | HP Compaq Presario V2000 Notebook
My compact presario v6000 wont boot up or the screen wont come on
Read this and then call HP at the number listed in the article. You might qualify for a free repair under a special enhanced warranty program. This is a known issue with your computer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Feb 24, 2009 | Compaq Presario Notebook
My friend has a Compaq presario f600 laptop & needs to replace the motherboard. What sort of motherboard would he need to get for it please?
I think I have the same laptop that also needs a motherboard. The Presario F600 also had a m/n of F572US found on the label with serial. Looking on the Compaq site I found the motherboard is the same as for the F500 notebooks which is 442875-001. Link is at: http://h10032.www1.hp.com/ctg/Manual/c01095493.pdf This number is also found under the memory chips on most Compaq/Hp Laptops. Simply open memory cover and remove the memory chips and there you will find the Motherboard replacement number. Good Luck!
Nov 03, 2008 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
