Question about Cuisinart Kitchen Appliances - Others
Cuisinart kettle electrical contact sometimes connects sometimes not
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
  • 18 Answers
SOURCE: Where can I find a replacement lid for Cuisinart Kettle CJK-17BC?
You need to talk to Cuisinart (follow this link to their contact us page http://www.cuisinart.co.uk/contactus.asp?menuId=20)
There is no harm in asking. I have had replacement cooker nobs, bin lids allsorts by just being honest with message and asking nicely.
But if all else fails EBAY =P
Posted on Mar 01, 2009
SOURCE: How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Posted on Mar 11, 2009
  • 3600 Answers
SOURCE: Our cuisinart electric tea kettle stopped working.
Most likey a burned out heating coil. You can buy them let me know the model number and I can give you a web site to go to buy it.
Posted on Aug 06, 2009
micromatikal
  • 2777 Answers
SOURCE: how to change the filter
I will be glad to help you here, but is it in fact the Cuisinart KUA-17 model as the question indicates? There is no "filter" in a KUA-17, so I think you may have another model here. What machine are you using? Please just reply to my answer here and I will be right back with you to answer the question for you.
Thanks so much, please let me know,
Tim
Posted on Nov 01, 2010
My Cuisinart electric tea kettle won't boil water anymore.
It may be under warranty. Normally electric kettles are considered a disposable item, but your one is state of the art and expensive!
Contact their service department for advice. It has a 3 year warranty. The bad news is that it has 15 one star reviews! Not good.
CUISINART CANADA leader in culinary appliances professional quality...
Jan 09, 2016 | Cuisinart Kitchen Appliances - Others
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
My Cuisinart electric tea kettle just stopped working - where can I get a new base? Model is discontinued CJK -17bc
I took the base apart an repaired the electrical connection. You need a special screwdriver to remove the 3 base screws. I took an old, cheap flat-head driver and filed a v-notch in the middle of the blade so it would work to remove the screws. Had to replace the connector because of corrosion. That fixed the problem for me.
Sep 18, 2010 | Cuisinart CJK-17BC Cordless Electric...
Our cuisinart electric tea kettle stopped working. Husband tested base and it has electricity to it.
Aug 06, 2009 | Cuisinart Kitchen Appliances - Others
Can I get a replacemnet base for the the cuisinart kua-17 tea kettle?
Yes, I opened the base (v-shape screws) and saw that the contact switch was burnt out. Where can I find the round contact switch?
Thanks.
Jul 02, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
Mar 01, 2009 | Cuisinart CJK-17BC Cordless Electric...
PROBLEM:
SOLUTION:
Nov 11, 2006 | Cuisinart KUA-17 Cordless Electric Kettle
Kitchen Appliances - Others Logo
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
