Question about Lello 2730 3000 Pro Pastamaster Pasta Maker
Need a manuel &replacement of broken auger /Lello 3000
My auger is broken, and I would appreciate a manuel, mine has disappeared
2 Suggested Answers
  • 248 Answers
SOURCE: Manual was not in box
kitchen.manualsonline.com
Posted on Oct 09, 2010
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
New augar motor wont run even in manuel
Try putting power directly to the auger. If it works then you need to see why you have no voltage on the auger motor terminal. Could be a problem with air flow vacuum switch, or loose/wrong wiring.
Feb 28, 2014 | Breckwell A-P22-EXT Maverick SP22 Pellet...
Lello paseta maker replacement parts
eBay has replacement parts for everything! If not, it will be very difficult to find them. Good luck!
Jan 21, 2013 | Lello Kitchen Appliances - Others
I am getting error code L4-02. Any solutions?
L4-02 - Drum Motor Lock.
  1. Remove the process unit, remove the drum & check the waste toner auger & gear assembly.
  2. You will probably find this is seized or broken due to excessive drum cleaning.
  3. When changing the drum & developer, you must reset the rotation counters as well as the drum/dev counters. Otherwise, there is excessive over-toning, leading to waste toner filling the toner cartridge waste area too quickly & therefore leading to waste toner auger assembly blocking up.
  4. You will probably need a new process unit as the auger drive gear has been known to break off the frame.
  5. There is new firmware for this problem. Have a service professional update the firmware for this device and the problem will be gone.
Feb 16, 2011 | Sharp AR-M355U Copier
The agitator is no longer attached
There is a small set screw located lower on the agitator. Locate the set screw and tighten. This should solve the problem.
Jan 05, 2010 | Maytag Washing Machines
Machine will not turn on
check the troubleshooting section in your manual. if you dont have it, find it here:
manualfox.com/link/lello.htm
Oct 20, 2009 | Lello 2730 Pastamaster 3000 Pro
The auger on my ice dispenser is broken
you should be able to get it in metal mine is in metal check with your apliance parts dealer in your area thanks from gilles
Feb 04, 2009 | GE GSS20IEP Side by Side Refrigerator
Lello 2730 3000 Pro Pastamaster Pasta Maker Logo
24 people viewed this question
Top Lello Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Lello Kitchen Appliances - Other Expert? Answer questions, earn points and help others
