Question about Mackie Onyx 1640i Mixer
SET UP PROBLEM
I have a imac with leopard or snow leopard 10.6.8 , i dont know the difference. Using logic 9. I bought this mackie 1640i and did the plug and play. Logic does not recognize the mackie. I have a m-audio project mix with presonus digimax fs all daisy-chain with firewire. I get 16 channels in and out with those but not 32 channels if the mackie was recognized. Do the 1640i work with snow leopard or leopard. HELP PLEASE
    Top Expert:
  • Mackie Master
  • 24,346 Answers
SOFTWARE/FIRMWARE required to work.
Drivers
PC: Windows XP SP3 to Windows 8
Mac: OS X 10.5 to OS X 10.10
Have a look here;
Onyx Series Production Mixers Mackie
Posted on Jul 15, 2017
4 Suggested Answers
  • 5603 Answers
SOURCE: I just got a mackie 1640i mixer yesterday. I
Likely you haven't got the levels set properly. Start with the trim controls (head end gain) Make sure you are not clipping there. Also verify you aren't overdriving your amps. Remember that the outs are line level, not mic level so the gain oof following equipment needs to be set for line level.
ALWAYS USE balanced audio line from this unit... either XLR or TRS type cables. ALWAYS power ALL interconnected equipment from teh same receptacle or source to avoid ground bounce damage to circuitry. You don't say what you are using to record with. Make sure it has balanced inputs. For instance, connecting cables from this to the audio input jack of a PC which is unbalanced would be a disaster in audio quality. There would be a problem of levels and the unbalanced thing... You haven't given us enough information of your hardware configuration to analyze the problem more than what I have said here.
Posted on Dec 26, 2010
  • 5603 Answers
SOURCE: Hi. I have a Mackie
Check the settings in your computer in the control panel "sounds and devices" under the "Voice" and "Audio" tabs. Check that all are set to the Mackie instead of the computers default input.
Posted on Jun 10, 2011
  • 5603 Answers
SOURCE: I have a mackie 12 channel mixer, but don't
Just use balanced audio interconnect cables (XLR or TRS) between the mixer and the M-Audio interface.
Posted on Sep 02, 2011
Hi there, my relatively new Mackie Thump wont power up despite being plugged in / on etc. When I do with it on all i hear is a very low pop sound every 5 to 10 seconds or so
Your best bet is to contact Mackie Tech Support. Here is a link to their Suppot page. Mackie Tech Support
it's likely it needs to go to a repair shop. Here is a link to their service center finder. Mackie Service Center Locater
Feb 05, 2015 | Mackie TH-15A Active DJ Powered THUMP...
Mackie mixer will not work with windows 8
well depending upon the mixer and windows version you may have issues. Windows 8 is a 64bit platform, your mixer may only have 32bit drivers (x86). Try visiting the mackie forum for your mixer.
Feb 17, 2014 | Mackie Onyx 1640i Mixer
Helicopter sounds flashing
Sounds to have some bad capacitors. These are what they sound like when they go bad. They burst open allowing germanium to escape.
Feb 21, 2013 | Mackie Onyx 1640i Mixer
No problem. just bought it and a pair of thump 15s what cables are best. and we want to play our accoustic gigs through this and dont know how to set eq i know its different each room but a starting point.
Use balanced lines for the audio interconnects. Use XLR low noise mic cables or TRS type cables. IMPORTANT: Power the speakers and the mixer from the SAME receptacle, even if it means running extension cords. Ground bounce in building wiring can destroy the circuits in the equipment.
Jul 11, 2011 | Mackie ProFX12 Professional Compact Mixer
Hi. I have a Mackie onyx 1640i. 2 days ago it was working, but now the computer sees only 2 output channels. There was no shock, etc... Thx
Jun 08, 2011 | Mackie Onyx 1640i Mixer
I just got a mackie 1640i mixer yesterday. I followed all of the correct steps in setting it up towork with logic pro. However, when listening to any audio coming through the mixer, there is this awful...
Dec 26, 2010 | Mackie Onyx 1640i Mixer
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
Mackie Onyx 1640i Mixer Logo
14 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
