Question about Kenmore HE5 Steam 7.5 cu. ft. Electric Super Capacity Dryer -
F-01 error when I try to start the dryer - Kenmore HE5 Steam 7.5 cu. ft. Electric Super Capacity Dryer -
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Dryer has f01 error
F-01 is a failed communication of the=> Whirlpool Dryer Main Control Board W10174745 The control board has likely shorted out. Not a cheap fix but it is a fix
APPLIANCE 911
Nov 28, 2015 | Dryers
What does code F 01 mean
For a start, google "Kenmore Dryer Model xxxxx error code F 01"
where xxxxx is the model of your dryer. Sift through the hits for an answer.
Pete
Sep 28, 2015 | Kenmore Dryers
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
May 04, 2014 | Kenmore Dryers
Maytag model MEDE500VPO what does the f 01 code mean?
Controller board malfunctioning.
Try looking at the video at
Duet Sport Dryer 2008 Error code 01
If repairs like this are not something you want to attempt, try calling a repairman, particularly if the dryer is under warranty.
Jan 04, 2012 | Dryers
E:01 error keeps coming on, what do we do
If you look on the insideiof the dryer door toward the top . you should see a clamp or something ..if that clamp or screw is broken it will nit operate and giv eyou an error messsage ... what we did was put a little screw back into that hole and made sure it;'s long enough to push in the button at the opening of the dryer .. try that .. if that does not work then you might want to try . to replace the dryer plug ( and or electrical box) if you have a 3 prong outlet and cord then that will give you the error message also , these dryers are picky ...
Oct 30, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Kenmore HE5 Steam 7.5 cu. ft. Electric Super Capacity Dryer - Logo
18 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
