Question about Sears Garden
I have a Sears riding mower model #917.255460 that the hydrostat transmission and wheels have locked up. Any thoughts how to fix.
The rear end has locked up however I have it jacked it up and the wheels move freely but will not move on the ground when engine is running.
    Habit-Forming:
    Scholar:
  • 54 Answers
I have answered,this similar question,and have given advice,what i would do. If you are a just a week end doer, i would not attempt to try to make your own repairs. This Hydrostatic Transaxle,is quite a complicated piece,You will need a profession,service technician to work on this. It has so many bearings,gears and a lot of small parts. This sound like,a gear is slipping,when the tractor is put in gear and under a load. It could be as simple as servicing,the Transaxle. I have seen this problem,when the Transaxle had air trapped in it. Your Owner's Manual,explains what to do,if there is air in the transaxle. You have to move the tractor about five in both directions. This usually,takes care of the problem. This occurs,sometimes after servicing the Transaxle. There is something thing you can do,check,for leaks of oil around the axles and or,at the Transaxle it self. It could be low on transmission oil. If this is the case,you will need to replace the seals. Unless,you know what your doing,i wouldn't attempt to dissemble the Transaxle assembly. Instead,call Sears for a repair service or call any lawn mower shop,that does this kind of repair.Sincerely,Brad Locke
Posted on Dec 03, 2015
4 Suggested Answers
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 12104 Answers
SOURCE: I have a crafstman riding mower. None of the
check drive belt probably slipping /stretched out and needs replacement
Posted on Apr 08, 2010
  • 640 Answers
SOURCE: Mower will not free wheel
Are you trying to push it? If that is the case, you have to disengage the transmission from the back. There is a linkage that sticks out the back panel and you have to pull and hook it. Then your mower will push freely. Remember to unhook and push in when you go to drive it.
Posted on Aug 20, 2011
Mower wont move forward or backwards and makes a ticking noise when pushed.
Just a thought , maybe the key that locks the pulley to the input shaft on top of the transmission has sheared and the pulley is just spinning on the shaft or the key on the axle shaft that locks the wheel to the axle and that would allow the brakes not to work.
May 19, 2016 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower wont push along . in nuteral , rear wheels locked ?
If it is a hydrostatic transmission, they have a lever (on the rear of the mower) that will lock out the transmission to allow pushing / towing.
May 06, 2015 | Garden
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I can not get my wheels to unlock on my riding mower LXT 1000 Model # 917 272461
which wheels are you wanting to unlock if it is a hydrostatic rear end that you wanta unlock to push manually then in the back of the mower there is a rod that you pull out or push up & over to release the axle
Jun 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have an ariens zoom 1540 hydrostatic mower. One wheel turns the other does not.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
Jun 11, 2010 | Ariens 34 In. Zoom Series Riding Mower
Apr 22, 2009 | Garden
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Garden Logo
104 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
