Question about Makita 3612C Router
Makita router model number 3620 Will Not start
You can Close the switch several times and maybe one current prices start
3 Suggested Answers
  • 178 Answers
SOURCE: I have a makita rd1101
Vince, it sounds like you will have to replace your variable speed module. It is item number (5) in the breakdown and runs about 80.00.
The part number is 631397-2.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=270
Click on the Parts Beakdown Icon on the left hand side of the page. I hope this helps, let me know if there is anything else you need.
Posted on Nov 25, 2010
rowdy45176
  • 2176 Answers
SOURCE: how to replace on off switch on makita router model 3600b
go to makitausa.com and you can download a breakdown for this tool. If you need more assistance let me know and I will help
Posted on Jan 11, 2012
Coil for sachs dolmar model 120 chain saw
Ignition Module Coil for Dolmar Maybe for your Country otherwise search by Makita also there are several equvalent parts to get forSachs Dolmar and its cheaper , beware on this to order ignition coils by mention on the serial motor number and the year of build by all orderings if it must be the right combination to get it can be important by marketing technical upgrades / modifications because of changed flywheels in several Dolmar models over past time i know. a suggested coil in a link
Oct 29, 2016 | Garden
Makita router overload reset
there is no overload reset. You have another problem, I am thinking the switch or cord. You can unplug and if you have a volt ohms meter start at the plug of the cord and work thru till problem is found. Usually the switch gets dust into it not allowing it to make contact.
Feb 21, 2012 | Makita Tools & Hardware - Others
How to replace on off switch on makita router model 3600b
Dec 28, 2011 | Makita & Plunge Router
Kenmore washer model 110 26712690 fills up with water and does nothing. wife said she smelt something burning. I thought maybe a belt but when I took it apart I didnt see any belts.
no belts in a kenmore,if it filled with water and stopped most likely you have a bad lid switch.close the lid,open it up a few inches and close it down a few times,if you don't hear a clicking sound every time you open and close it the lid switch is bad.,if you already have it apart,you can jump it out,the white harness you disconnected next to the right clip is the lid switch harness,stick a wire in the two outside holes,put it on spin and pull the timer out,it will run.the model number you sent isn't correct,i was gonna give you the part number and price of the switch,just give it to your parts store and they will sell you the correct part.
May 15, 2011 | Kenmore 22422 Top Load Washer
I have a makita rd1101 2.25 hp router it has adjustable speed. the router has been used maybe several times. Just recently while using it the speed will drop down for a few seconds and then rev back up...
Nov 25, 2010 | Makita RF1101 Electric Routers, Fixed &...
I am having difficulty changing the cutting bit on a Makita 3620
If I understand this right you can't remove the bit from the collet. If this is true there might be dirt on the collet and you can try and blow it out with compressed air. What I would do if that doesn't help is support the collet nut allowing the bit to hang free and gently tap on the back of the bit and this will remove it. It is possible that you may have overtightened it or the bit has a burr on it. Good luck
Dec 31, 2008 | Makita 3612C Router
Maikita bhp 451 transmissions
the gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Nov 02, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 3612C Router Logo
41 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
