Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet has mold on rubber around the door
Whirlpool duet frontloaded has mold around the door
jsrock516
  • 5911 Answers
SOURCE: need instructions to replace the
Here ya go...follow this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you get stuck along the way and/or require further assistance, please let me know. I hope this helps you.
Posted on Jul 04, 2008
Lumpy816
  • 246 Answers
SOURCE: whirlpool duet sport frontloader washer, door wont open, locked up.
Not a problem glad we could help.
Posted on Jul 11, 2008
jsrock516
  • 5911 Answers
SOURCE: sour smell coming from inside whirlpool duet front loader
Residual water sits inside the wash tub under the stainless steel basket and in the drain lines & drain pump. This is normal. If you are in the habit of using very few hot water cycles and do not leave the washer door open when not in use, bacteria, mold and mildew can build up and cause the sour smell you are experiencing. The following link provides some good info on how to prevent these odors:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
You may also want to remove the drain pump reservoir and check to see if you have anything caught. Sometimes debris can build up in the drain pump and cause odors. The following link explains how to check the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I personally own a front loader such as yours and have never had a problem with odors by following this simple advice. Occasionally run a sanitary cycle with nothing but bleach in the water. For washers with no santitary cycle, run it on the hottest setting you have. Sorry...front loaders require a bit more TLC than conventional top loaders. I hope this helps you. If you have questions, please let me know.
Posted on Aug 18, 2008
SOURCE: whirlpool duet washing machine
I work at Whirlpool, and we recommend a product called Affresh to help eliminate washer odor. Affresh washer cleaner tablets break up many of the residues that bacteria, mildew and mold grow on, and it removes them, leaving you a cleaner washing machine.
For a limited time, they’re running a promotion on whirlpool’s website that will get you free shipping on a 3 –pack of Affresh tablets! You just enter EAF822 as the promo code, and they’ll ship you the packet at no cost to you!
Posted on Aug 26, 2008
SOURCE: Black mold growing on rubber
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Posted on Mar 16, 2009
Cleaning rubber door boot
I am not sure how the Whirlpool rubber boot is constructed but the Maytag's can be pulled back enough to get a sponge, washcloth, etc. around it to clean it. If you can get to it try a product like odorban which will clear up any mold, mildew & icky smells without harming the rubber itself.
Mar 03, 2010 | Whirlpool Washing Machines
Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rotting Smell from Whirlpool Duet Front Loading Washer
Take the panel off of the front of your washer below the door and in the middle there is a round removable plastic door like piece. Take it out and clean out all of the junk in behind it. You might find loose change, nails and a variety of other thnigs that have become stuck in there besides mold. This will help with the smell and also the water that sometimes remains in your washer after the cycle is over. You need to do this once/twice year.
Feb 12, 2009 | Whirlpool GHW9100L Front Load Washer
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
d
Oct 12, 2008 | Whirlpool Washing Machines
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
