Ge washer top load wbse4220aoww - Washing Machines
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Posted on Jan 13, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
FixinFax
  • 3085 Answers
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
Posted on Nov 25, 2009
  • 512 Answers
SOURCE: low water level in top load washer
Load selector switch has a hose attached to it that goes to bottom of washer tub. It is probably clogged with soap. Open top where switches are, disconnect tube and blow it out. Problem should be solved. The only other thing it could be would be load selector switch has gone bad. But I am betting tube is plugged.
Posted on Feb 25, 2010
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Low water level in top load washer
Feb 25, 2010 | GE WBSR3140DW Top Load Washer
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
Nov 25, 2009 | GE WBSR3140DW Top Load Washer
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
GE washer model #wle4000b1ww won't spin
This is joyce
You have a bad belt it wont pull the load.
thanks,
joyce
Feb 04, 2009 | GE WPRB9220D Top Load Washer
Removing cover assembly on GE top load washer
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
