Question about Canon PIXMA Office Equipment & Supplies
Cannon mg8100 error code 5100
I am getting the "5100" error code repeatedly after shutting down and restarting printer. It makes a loud screeching noise when restarted. It happened just after putting in a new ink tank. I cannot see if ink is seated properly because the ink carriage does not return to the center of the printer. If this something I can repair myself?
SOURCE: error 5100
Have you taken the printer apart? as the issue I had with our spare printer was that the home mechanics around here had taken ours apart for some reason and had not put the paper roller pin back in correctly. it was sticking out preventing the ink tank holder from moving.
Posted on Jan 07, 2008
SOURCE: HP 3310 printer
my ink cartridge door is open and I can't get it closed.
Posted on Dec 08, 2008
yboyandrei
  • 828 Answers
SOURCE: I have a ip5000 that has service error code 5100
I had the same problem. all i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine.
Tips:
#1 Move the cartridge holder back to the right manually, but carefully - close lid and turn the printer off, then on again.
#2 Move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on Aug 10, 2009
copiersplusw
  • 136 Answers
SOURCE: error 010-397 restart printer
I would Hold down the "Menu" and "Cancel" Button then for "Reset Printer" ,Turn Off the Printer remove the cartridges then reset them again. Along with the Drum Unit. Something is Not Seating properly
start thier first.
If I could be of further help or your in the CT area then contact us:
http://www.copierspluswwllc.com
Posted on Oct 10, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip6210D. Error 5100. Ink carriage will
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Posted on Jan 25, 2010
Getting error code 5100 - what does this mean?
you need to reset your cannon by turning it on and off... for more detailed instructions follow this link to a faq on the issue from the cannon website
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 20, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Tips:
Aug 10, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Keeps restarting
I do not know about the screeching part, that could be part of the problem or completely independent of the problem. When my machine kept repeating the "startup" process, it was because my bulbs went out. The printer then would never get warm enough to melt the ink to begin printing, so it would just keep restarting, and restarting the warming up process. One way to tell is to take off the side cover. Then peer into the side and see if you see a bright light - which would be your bulbs. I have no idea though what to tell you about the screeching thing.
Jun 03, 2009 | Xerox Phaser 8200 Laser Printer
Error code 5100 on my printer cannon ip 1700
por favor necesito ayuda para una impresora cannon mp180 despues que la mando a fotocopiar y va a tomar la hoja me sale el error (servicio impresora 5100) les agradezco me estan atacando
May 04, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Error 5100
Dear Scub,
Did you hear a loud crunching sound from the printer before the error code 5100 was displayed?
1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours.
Checking and do-it-yourself inkjet printer repair is messy.
2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the **** strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol.
If these does not solve your problem, guess your back to # 1.
Cheerup And Be Happy always
Mar 25, 2008 | Canon Pixma MP450 All-In-One InkJet...
ERROR 5100
Hi, Did you hear a loud crunching sound from the printer before the error code 5100 was displayed? 1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours. Checking and do-it-yourself inkjet printer repair is messy. 2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the slit strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol. If these does not solve your problem, guess your back to # 1. Good luck and kind regards.
Aug 26, 2007 | Canon Pixma MP450 All-In-One InkJet...
42 people viewed this question
old marine
old marine
