How to tune up 2008 toyota rav 4
As the cars technology advances, the term tune up is fading and replacing with term Scheduled Maintenance Service. For most of the cars the time for these maintenance service is at 30K, 60K and 90K. You have to choices:
Service your car by yourself, or send to a dealer. Because maintenance services might be as basic as an oil change, air filter replacement, or more complicated as brake job, coolant system flush, brake fluid flush, transmission oil and filter change, and finally as complicated as, timing belt/chain replacement, if you decide to service by yourself, I recommend to Haynes Repair Manual, Specific for your car.
For your car Toyota provides all Scheduled Maintenance Services according to the miles on your car at:
http://smg.toyotapartsandservice.com/
The answer for your question based on Toyota blog is:
Replace engine oil and oil filter
Rotate tires
Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Tighten nuts and bolts on chassis
Driving on Dirt Roads or Dusty Roads
Inspect ball joints and dust covers
Inspect drive shaft boots
Inspect engine air filter
Inspect steering linkage and boots
Re-torque drive shaft bolt (4WD)
Applicable Footnotes:
1) Reset the oil replacement reminder light ("MAINT REQD") or the message "OIL MAINTENANCE REQUIRED" on the multi-information display after engine oil replacement.
