Question about GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven
JES1453SR1SS on off button broke
The button that you push to open microwave door broke off.
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Posted on Feb 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: door won't open. push button doesn't work
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave JVM1851WD001, buzzes if
That is a control circuit board issue which we regularly repair with our $39.95 service nationwide.
Or if you prefer, you can order a new smart board / PCB assy (part number WB27X1043) from the Pros here, our favorite supplier. It runs $259.53.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jun 21, 2011
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
My push button to open door broke. how do I get the door to open?
Disconnect microwave from power socket, remove cabinet outer cover,and lift the top or bottom door latch at micro-switch bracket with a screwdriver, the door can then be opened.
Oct 24, 2015 | Maytag Appliances Over-the-Range Microwave...
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
Broke a hinge off our microwave door. Can't open it, don't know how to fix it.
If the hinge piece broke off, can you show it? Have you pushed in while pushing "open"? Tried to GENTLY pry the door at the edge with straight slot screw driver?
Mar 06, 2013 | Microwave Ovens
Push button won't open door
the door lever is broke behind the button
Feb 05, 2010 | Microwave Ovens
MICROWAVE GOLD MICRO DOES NOT OPEN
sound likes the push button spring broke or popped out of place. if you unplug unit remove all screws going around the back edges. take panel off all the way around ,then you will be able to check spring and bbutton. the ones ive worked on the puch button cradle is usually broken and can be replaced as long as its not 20-30 yrs old.do it yourself 15-30 dollars in shop repair 65-95, in home service around 85-145.00 dollars. depending were you live.
Sep 16, 2009 | Whirlpool RMC275PD Microwave Oven
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Oct 27, 2007 | DCS CMO-24-SS Convection/Microwave Oven
GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven Logo
199 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
