Question about Bose Wave music system Multi-CD Changer 3-Disc
Where can I buy a cd error disc - Bose Wave music system Multi-CD Changer 3-Disc
Getting disc error when cd is present.
The problem is in the laser pickup assembly, buy a CD cleaning kit and follow instructions, If that fails! it must go back to Bose for sevice the only way.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Every time I put blank cd in recorder side of unit it initializes and then says opc error then disc error...I've had it for about 8yrs
its prbly indicating that the burn laser is no longer functioning especially if the burner has had alot of use prbly still poss to buy parts however could be costly
Oct 12, 2010 | Philips CDR778 2-Disc CD Recorder
Dvd player isn't working, tuner working, i am not sure what happened, it says that there is no disc. worked unitl few days ago, company out of business.
Hello
Ok, the no disc error is not good...
Firstly, i must inform you that there might be a possibillity that the laser lens which actually reads the dvd/cd is burnt out.
Is there a possibillity that there is a cd stuck in the trey?
One other thing you can try is to buy a laser lens cleaner disc, this looks like a cd/dvd, but is cleans the laser lens in the player. This error sometimes occur when the laser lens itself has some dust particles on it.
The other alternative is that you replace the laser lens itself, which is not worth the money.
You can buy a new unit for this replacement fee.
You can buy the laser lens cleaner disc at any cd or music store.
Kind regards
Andrea
Dec 16, 2009 | Koss KS3102 System
Solution to power caliberation error in burnings softwares
I have experienced the exact same error on my system. However, i only happened with DVD's and not CD's. So I tried a few more DVD's, got the same error. Decided to gove it one more try, and the next disc worked! Burnt very slowly but it did eventually finish. The one after that worked as well.
I suspect it's the media (Discs) you are using may have some factory defects with them. Try another disc from the same pile, or eve better, buy a different brand and try those.
Hope that helps,
Cheers
Jul 14, 2009 | Mad Dog Multimedia MD-5216CDR (20681870)...
CD Player won't read disc's. ERROR message
Well if the unit came with car over 10 years old, u can't clean it might have to just replace. buying a new one will cost as much as trying to fix that one.
Apr 10, 2009 | 2003 Dodge Grand Caravan AWD
CD "disc error" in Jeep Grand Cherokee
BE SURE THE CD THAT CAUSED THE PROB DIDNT HAVE ANY TYPE OF STICK ON LABEL THAT MAY OF COME OFF INSIDE, ALSO IVE SEEN CHILDREN PUT COINS IN THE CD SLOT IF YOU HAVE CHILDREN. MAY WANT TO TRY A CD LENS CLEANING DISK PROB FIND AT RADIO SHACK OR BEST BUY TYPE STORE.
Oct 01, 2008 | 2005 Jeep Grand Cherokee
CD's
wi not. you get audio discs and DTS discs in may music worlds.
many of the players from SONY show tis problem. the dont play lot of CD formats.
so better use AUDIO CDs and DTS CDs...
Dec 23, 2007 | Audio Players & Recorders
Will not read discs
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Sep 29, 2007 | Nintendo Wii Console
Bose Wave music system Multi-CD Changer 3-Disc Logo
70 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
