Question about Minolta EP4000/5000 CS/PRO Copier
My copier give code c0500 - Minolta EP4000/5000 CS/PRO Copier
    President:
  • Minolta Master
  • 1,447 Answers
C0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Please change upper roller
Posted on Jul 23, 2014
4 Suggested Answers
  • 990 Answers
SOURCE: Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Posted on Dec 15, 2008
SOURCE: error code c0500
open back coever then press reset switch from mainboard
Posted on Oct 02, 2009
Daniel S
  • 4323 Answers
SOURCE: Problem on Minolta DIALTA DI
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
C0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 01, 2014 | Minolta Di3510f Bizhub Copier
Machine give a coade c0500
The error code C0500 deals with the fixing unit temperature. I could be a blown fixing lamp or thermal fuse or thirmister. You did not give the model number, so I can not tell you how to reset the error code. Good Luck
Nov 02, 2013 | Minolta Office Equipment & Supplies
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
IT AUTO CUTS POWER AND GIVES A CODE THAT IS C0500
i have a SF- 2510 sharp copier that is displaying the error code C0500. What does this code mean and how do I fix it?
Feb 23, 2011 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Di2510 error code C0500,can not reset error code
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Nov 22, 2010 | Konica Minolta DiALTA Di183F Copier
My Oce im2520f is giving me an error code: C0500. After about 3 minutes of giving me the error code, it beeps four times (long beeps) and then in shuts off. Anyone have any idea what it might be?
The C0500 error code is a fuser unit error code. The fusing unit is the part that gets hot and "fuses" the toner onto the paper just before it exits the machine. There is a special reset procedure for this code so as to prevent overheat of the fuser. You will need a service technician to diagnose the problem in the fuser and then reset the code. Most common causes are blown thermal fuse, bad thermister or rarely, a bad heater lamp.
Good Luck and Thank You for using Fixya.
Mar 19, 2010 | Office Equipment & Supplies
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Code C0500
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
