Question about Estate EED4400WQ Dryer
Dryer will only run on one setting and does nothing on the others
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Samsung DV409sel Fairly newv (less than a year) Settings are seleted, start is pressed, a click is heard inside but the machine doesn't start. Flashing clothe icon on display. Tried different...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Dryers
I have a maytag dryer(the lesser quality one) about 5 yrs old. stopped mid cycle. now i get nothing.dead as a doornail.I tried different positions of settings to see if it might be timer...nothing.....
Thermal fuse LA-1053 runs $25,pop the top using a putty knife,two spring clips in front about 4 inches in from the side,tstat sits on the heater duct behind the drum...
Sep 20, 2009 | Maytag PYE4557A Dryer
Roper dryer will not start
Did you check where the door closes. There should be an accuatator on the door side that will depress a safety switch inside the housing. Take a flat scerw driver & push the lever in on the switch in the housing once you have set the controls to run. This could be the problem, but there could be other problems, Good luck.
Jan 21, 2009 | Roper REK2950W Electric Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
A little heat then nothing
Yeah...that's coils 99% of the time.
Jan 10, 2008 | Kenmore 72802 Gas Dryer
Estate EED4400WQ Dryer Logo
24 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
