Question about Mitsubishi WD-73640
Wd73640 freezes on blue welcome screen - Mitsubishi WD-73640
Blue screen no pic or audio. the only input that works is the cable input. All others: HDMI 1, 2, 3, component, and composite, give a blue screen with the label for the input.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here
Feb 13, 2017 | Televison & Video
How do I get to the inside to clean my wd73640 tv ?
If you mean removing the casing ... there may be components with a residue charge that can shock you even if its unplugged, and not grounded. Does your manual mention mirror cleaning?
-GWOOD
Jul 16, 2014 | Mitsubishi WD73640
Blue sceen ASUS 3 Motherboard - M4A88TD-M EVO
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Tracey Laidler.
Yes you are quite correct BSOD or Blue Screen Of Death is normally due to a memory fault. However drivers are as big a culprit, especially seeing as though you have changed memory modules and processor.
Install all the drivers for this mainboard.
Also enter the BIOS/CMOS by tapping the Delete key during first powering on the computer.
Once in the BIOS/CMOS select the option to load defaults.
Check if that works.
If not then take it a step further by clearing the BIOS/CMOS by removing the silver button cell from the mainboard for 10seconds before reinstalling it in the correct orientation.
Take care!
Dec 15, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
I have a 4 year old Toshiba laptop running XP sp3. When I try to boot it up, it freezes at the blue "Welcome" screen and I have to turn it off by holding the power button. The keyboard works (mouse will...
Hi Good day!! there's a tricky way of your problem in the welcome screen try to press ctrl alt del at the same time. NOTE don't Enter it!!! after you press ctrl alt del press esc button see if it work i hope it works...
Oct 09, 2010 | Computers & Internet
Blue Screen
The blue screen (known as the blue screen of death or BSOD) is usually caused by hardware failure. If you have the warranty available, you can contact Durabook and they will be able to assist you with that problem.
Oct 08, 2009 | Twinhead DURABOOK D15TS (D15TS17TL80M3H)...
Turn on ps3 screen freezes on welcome screen.
google: rescuetechla
look for my blog page.
Check the 5 most common PS3 problems section and pay attention to # 3.
Hope that helps.
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-73640 Logo
13 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
