Question about Whirlpool AWM8143 Front Load Washer
Flashing f23 on Siemens washing machine s14-49 model
3 Suggested Answers
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
caroldon
  • 17130 Answers
SOURCE: f23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Posted on Jul 05, 2012
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
F 23
The meaning of the code depends on the machine's manufacturer.
On Siemens built machines (Siemens, Electrolux, hotpoints etc.) F23 Means that there is overflow and anti flood device has been activated.
In this case:
Disconnect power.
Remove all water at the base of the machine.
Take off the rear panel, or access the drain pump from front door(depends on model).
Check drain hose height and check hose connected to drain pump.
Connect power back.
If problem does not clear after connecting back, replace pressure switch.
With Wirlpool built machines instead (Whirlpool, Maytag, Kenmore etc.) f23 means there is a communication within the CCU and the MCU.
CCU is the main control module (central control unit), and MCU is the Motor Control Unit. MCU is a sealed module located deep inside the appliance, and connected on one side to the motor, and on the other to the CCU. Testing F23 on a Whirlpool is more difficult and requires a technician. In this case all you can do is disconnecting power, if error does not go away call the service number listed on manual.
Regards.
Ginko
May 19, 2011 | Washing Machines
The washer is flashing F23 and won't run. Why?
Hi
F: 23 means that your machine is leaking and should be repaired. This is often a due to a bad seal.You need to unplug your machine to check for any leak.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Siemens WE61021GB Front Load Washer
I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
F23 fault
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Oct 25, 2008 | Bosch Logixx WFT 2806 Front Load...
Whirlpool AWM8143 Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
