Question about GE Refrigerators
Pss25SGMB BS thermostat replacment
Refrigerator side is too cold sometimes even freezing even though its set 37 degrees. Sensor reads at a much higher temperature.
4 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Posted on Jul 16, 2010
  • 2468 Answers
SOURCE: GE profile side by side
you need to check and see if the plastic flapper on the damper vent door has frozen open and broken,you need to remove all the air flow parts to check this physically,you can run the diagnostics,and hear the damper motor run,but if the door is broken and stuck open you cant see this without removing the plastic grill covers and all the plastic parts from in front of it,even where the light bulbs are located in the roof of the refrigerator,if this isnt it,then you may have bad thermistors in the side of the refrigerators walls,the diagnostics will tell you this in a pass/fail test,g.e. has had a problem with these damper doors though in the past
Posted on Dec 03, 2010
richroth
  • 9472 Answers
SOURCE: Food items are freezing in
Check to see if there is ice buildup around the damper door in the refrigerator section. Post back your results.
Posted on Aug 31, 2011
I have Hussmaan HGL-2-BS. It runs for a while and starts to freeze even though the thermostat is set at above zero degrees. What is the solution
Sounds to me the thermostat will need to be replaced. If the control is electronic it may be related to a defective thermistor sensor telling the electronic control the wrong temperature.
APPLIANCE 911
Jul 11, 2016 | Refrigerators
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
Temperature in the FF side dropped to low
Hi Steven,
Sensor / thermostat problem.need to replace.
regards,
nuwan.
Jan 27, 2014 | GE Profile PSW26P Stainless Steel Side by...
Sometimes when the refrigerator temp is 37* some of the food will get frozen.
Your thermostat is faulty. The vegetables cannot freeze at 37 degrees. It will not freeze until it's at 32 degrees. The sensor is wrong as it is impossible to freeze anywhere above 32.
Sep 08, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
Step 2
Step 3
Step 4
Step 5
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Produce is freezing in refrigerator
might need thermostat replaced. use thermometer at different thermo settings to see if any changes
Dec 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
