Question about LG LRSC26980 Refrigerator
LG ice maker tray leans and pours water - LG LRSC26980 Refrigerator
SOURCE: Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Posted on Apr 18, 2008
SOURCE: LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Posted on Mar 08, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
SOURCE: Ice not dropping
Press the little button on the bottom right of the ice maker and clear the tray of ice. The maker has to be turned on for the tray to tilt and empty. This corrected the problem for me. The freezer side may have been left open and and the ice maker filled the tray while the door was open, I suspect.
Posted on May 14, 2009
Water running down beside ice maker
is the water over pouring into the ice cube trays? Some fridges have a adjustment option where you can choose how much water the fridge puts into the tray - modify this setting if you have it, or contact lg for a repair.
Jan 14, 2014 | LG LRSC26980 Refrigerator
Water continually flowing in freezer section
If the water do not stop then turn off the faucet. This could be caused by a bad ice maker.
Feb 11, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Not making ice unless I pour water in tray, water does not flow from small plastic line that feeds tray. I did clean screen at suppy line.
It could be the water valve or water switch in the icemaker. Now it doesnt call for water until the thermostat is satisfied.Now if you pour water and it goes thru and dumps into the bucket I would try to change the valve.
Sep 29, 2009 | U-Line Icemaker
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice not dropping
Nov 12, 2008 | LG LRSC26940ST 36" Side-by-Side...
LG LRSC26980 Refrigerator Logo
20 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
