Question about Vacuums
Buy Model 12120BF
Motor doesn't work
Doesn't turn on
Gain access to the electrical connection with voltmeter set to 110 v ac check for voltage on both sides of switch. If voltage is present on outlet side follow output wire to start relay ck for power on out put side of relay. if power follow output wire to motor if voltage is present replace motor ! Be careful where you touch when probing contacts !
Dec 29, 2012 | Kenmore whispertone 100 model 116
Indicator light comes on but sweeper doesn't run.
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
Jun 06, 2012 | Kirby Heritage II Vacuum
The motorhead on my dc05 doesn't work.
Hi David,
I'm sorry to hear you're having difficulties with your DC05 Motorhead. I'd encourage you to give our customer Helpline a call on 0800 298 0298. One of our advisors will be happy to run through some troubleshooting checks over the phone with you to help determine the cause of this issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 14, 2012 | Dyson DC05 Bagless Canister Cyclonic...
The motor still works but it doesn't collect the dust
did you check all hoses to see if they are clogged? there is a spot at the bottom of the vac where it sucks the dirt/dust into the bag. if there is anything clogged in the hoses it will not allow suction. plus you may want to check the filter if your vac has 1.
Apr 10, 2012 | Vacuums
GE blender model 169169 jar broke, trying to find out where to buy replacement picher (glass)
I have the jar since my motor base stopped working. Make me an offer and I'll mail you the blender jar. Tom
Sep 03, 2011 | Vacuums
Blue sparks from motor stopped working
either cord shorted out or switch failed would replace cord first if that doesn"t work probably have to take into repair shop
Jul 04, 2009 | Kirby Vacuums
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Jun 14, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Vacuums Logo
57 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
