Question about Miele W4840 Front Load Washer
I close the door and try to start the washer but then the machine says its open. How do I fix this?
How do I fix washer that will not start after I opened door and manually advance to next cycle?
Unplug the machine and replug it - also remove the washing and go through the process again
Jul 23, 2014 | Roper Washing Machines
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Kenmore Elite HE5t washer - Door is hard to open and close
It may be sprung in the hinge or there may be a tiny piece of debris causeing the door to hang when being opened or closed.
Jun 03, 2012 | Kenmore Elite HE5t Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
F26 code comes up when i try to start washer; won't allow me to start machine. What can i do to solve this?
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Jul 07, 2010 | Kenmore HE3T Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Front load washer won't start unless door open and closed over and over
the door latch needs a spray of crc into it as it may be a little dry inside there
that should fix problem
if not replace door switch
Mar 15, 2008 | Washing Machines
Whirlpool Duet Front Loading Washer Imbalance causing front door not to close
Plug off the wall, open the top of the machine, check to see if any wires have come loose in the door lock area, tighten up.
Nov 14, 2007 | GE WBVH6240F Front Load Washer
Miele W4840 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
