Question about Belkin Inc Wemo Switch
Troubleshooting a memo remote switch problem
Won't open the connection
I have bought a new asus memo 7 and i cannot connect it my wifi, it keeps saying authenticating problem
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
Oct 08, 2014 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
Bluetooth won.t connect
You may need to pair the bluetooth again as it may have lost its pairing id sync.
Delete the pairing if it exists and start from the beginning.
Apr 18, 2014 | ASUS MeMO Pad HD 7
Trunk won't open
check voltage to actuator when energized(pushing button on key)when pushed should have 12 volts dc,if yes actuators bad,if no bad connection somewhere
Nov 13, 2012 | Lexus 2005 ES 330 Base
97 aurora driver door won't lock after programming new remote
OPEN UP DOOR PANEL......A CONNECTION (ELECTRICAL) OR MECHANICAL LINKAGE HAS MOST LIKELY BECOME DIS-CONNECTED
Jul 30, 2012 | Oldsmobile Aurora Cars & Trucks
Doors won't lock, thinks key in ignition
Troubleshooting is required to inspect few parts.It can be issue with ignition switch.Its not getting off.Or issue with sensor or wiring.Or its faulty lock itself.Click the link below and follow the troubleshooting:----Driver Door will not lock or unlock with Key or Remote? http://whatisbyme.blogspot.in/2012/05/1998-toyota-landcruiser-driver-door.html
Driver side door will not lock or unlock with Remote? http://technoanswers.blogspot.in/2012/04/2009-toyota-tundra-driver-side-door.html
Central locking not working ? http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
Jul 17, 2012 | 2002 Subaru Outback
Thermostat model UMC 117 keeps coding C7 why?
Generally, C7 is communication problem with remote
Error codes are considered start point for troubleshoot.
Causes can be: Bad remote, bad wire to remote, loose wire connection at remote, loose wire connection at unit, bad PC board.
In no particular order:
Check wire connections.
Disconnect remote and let water heater control temperature at default 120 degrees F, and if no further problem develops, then that might eliminate PC board as source of problem.
Replace wire to remote.
Replace remote.
Call service technician to diagnose problem.
Contact Rheem about PC board and other options.
Before calling service technician, open following links for troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
Installed new battery. Everything working perfectly except for the recording capability of voice memo. Playback of existing files is fine, but I cannot record a new voice memo file.
Re-open the case and make doubly sure that the tiny connections to both the mic and the record button are firmly connected and not broken. Lots of very small and delicate connections in very tight quarters in a unit that was not designed to be user serviceable.
Jun 28, 2009 | Palm Zire 72 Handheld
Belkin Inc Wemo Switch Logo
49 people viewed this question
Top Belkin Inc Computers & Internet Experts
David Payne
David Payne
Are you a Belkin Inc Computer and Internet Expert? Answer questions, earn points and help others
