Question about NAD C565BEE CD Player
Disc error after inserting the disc and the reading disc error is displayed
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
The wii won't read the disc
Situation:
  • System displays either error message "Unable to read disc" or "Disc could not be read"
What to do:
  • This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
  • Verify that the disc is being inserted properly.
    • If the console is placed vertically, the disc label will face to the right. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
    • If the console is placed horizontally, the disc label will face upwards.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Situation Not Resolved:
  • If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
  • If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
function rvl_ts_sys_unable_read_disc_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_unable_read_disc",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_unable_read_disc_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } function rvl_ts_sys_unable_read_disc_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_unable_read_disc=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_unable_read_disc_techDif(){ //it broke document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_unable_read_disc_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_unable_read_disc_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } Was this information helpful? yes.png no.png
Dec 25, 2011 | Nintendo Wii Console
My WII will not read any disk and we do not have a menu. All it will say is unable to read disk.
Unable to Read the Disc / Disc Could Not Be Read Situation:
What to do:
Wwhy 9101 in display? i am brasilian.
hi 9101 is mechanical time out error. When u insert disc to ur CDJ
and that is not able to read disc within the given time then
error 9101 display.
Please try to clean laser and compartment of your CDJ, their may be dirt, dust inside it. I hope this will help.
thx
djajay
May 25, 2010 | Pioneer CDJ-100 Turntable
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Jul 23, 2009 | Panasonic PV-20DF64 20 in. TV/DVD Combo
Error 08 / Disk Locked error
With help of Yamaha tech staff, I inserted a business card under disk "lid" in bottom left corner, slid card to right to release catch. With catch released, pushed disc in to insure in OK, closed lid cover, then slide card from lower right corner to left to re-catch. Read disc OK.
Jun 12, 2009 | Audio Players & Recorders
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
May 29, 2009 | Pioneer Car Audio & Video
After loading, disc error is displayed when dvd is inserted
hello i have had the same problem this maybe because of the region that your dvd is made to play.different dvd players play different.region dvd the regions should be on the dvd and the dvd cover.
Apr 25, 2009 | Televison & Video
JBL Error 1
Error one is unique to the disc being inserted into the player.
According to the service manual, this is the exact statement:
Err 1 appears on the display:
This indicates that the disc is dirty, scratched, damaged, incorrect (as in a "burnt" disc), or has been inserted upside down. Clean the disc or insert it correctly.
Toyota CD players are very sesnitive, and the svc manual specifically mentions not to use anything other than "store-bought" CDs.
Jun 03, 2008 | 2001 Toyota Sequoia
NAD C565BEE CD Player Logo
89 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
