Question about Waring WMK300 Professional Belgian Waffle Maker
Toggle switch and circuit board will not turn off and on
Will not turn off and on,,,
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Need switch for mod 338.179220 wet/dry vac
If this is the Sears vac with the toggle, snap out the toggle drill a 1/2" hole and insert an off the shelf switch. The original switch has four terminals; take the ground wire, usually white, and permanently connect . eliminating the switch and run the black circuit through the new switch. OR
Permanently eliminate both sides of the switch by connecting the two circuits and turn of the vacuum by pulling the plur or putting a switch on the outlet. or
Go to Sears direct and pay the price fo a new switch.
Jun 25, 2012 | Craftsman 12 Gal. 5-peak Hp Wet/dry Vac -...
I am trying to install a double pole pass and seymour toggle switch to electric outdoors for a pool pump and pool timer. this switch appears to match the old one so I tried to wire it exactly the same. All...
Hi Jeremy,
You need a double pole or S2 switch rated at least for 240V / 20A.
It sounds like you're describingt a four way switch or S4. A quick check of the handle (if the traditional toggle type) can help you identify the switch; it should have "ON" and "OFF" indicated on it if it is an S2 and nothing at all if an S4. S4 switches almost always have four brass or gold colored screws while S2 switches nearly never have four brass or gold colored screws (not counting the green ground screw - of course).
One or more S4 switches are used between three way or S3 switches when 3, 4, 10, 20 or more switches are needed to control lights or other devices (typical usage to turn lights on and off at each floor to a stairway in multi-level buildings. These are typically 120 volt residential circuits in the U.S..
S2 switches are required when controlling two hot wire circuits that need both hot wires to be opened when shut off. These are typically 240 volt residential circuits in the U.S..
I hope this helps & good luck!
Apr 15, 2012 | Electrical Supplies
I need to buy a SPDT low voltage momentary contact toggle switch.
You want toggle switch that mimics operation of pushbutton, except you want SPDT.
For example doorbell button is a momentary SPST
http://www.mrsupply.com/leviton-5657-2w-double-throw-ctr-off-momentary-contact-switch.html
http://www.csnlighting.com/Legrand-TM811DTMOBK-LEE1616.html
For others finding this thread: Many people want double throw switch for 240V, thinking they have to turn off both hot legs of 240V circuit.
240v can be turned off by cutting power to one hot leg.
http://waterheatertimer.org/B220C.html
Aug 01, 2011 | Lutron Ivory - Ariadni Dimmer - Magnetic...
My Brew Central will not come on when I flick the toggle switch. This just started about a week ago. Had to use a back up coffee maker, then a few hours later it came on just fine. Then again for...
mcdevito75 here, Sounds like the toggle switch is going or gone, if the toggle switch is a circuit board you:ll have to replace the machine, check with any appliance repair outlet in your area.
Jun 28, 2010 | Cuisinart DCC-1200 Coffee Maker
Cooling fan is not coming on at all how do i wire it up to come on when car is started and stops when car is turned off
Here is a wiring diagram of how you should by-pass that cooling fan by using a toggle switch, and you can get a fuse holder and use a 30 amp fuse instead of a 30 amp circuit breaker, but you should use the circuit breaker since you are no longer using a relay, and if there is a voltage spike the circuit breaker will reset itself, and a fuse will blow out and you will have to change it. Most auto parts stores will carry the 30 amp toggle switch and circuit breaker, also be sure to use 10 ga. wire and do not forget the wire connectors that you will need to attach the wires to the toggle switch, the circuit breaker, and to the battery as well as the connection to the cooling fan wires.
This wiring diagram is very basic and you should be able to follow it with little difficulty, and you should also dis-connect the cooling fan at the wiring connector to the cooling fan and connect the by-pass wiring directly to the cooling fan motor so that you do not run voltage back through the stock system. Let me know if you require further assistance.
Jun 04, 2010 | 1992 Pontiac Bonneville
Want to wire up toggle switch to run turn signals on car.have 3 way toggle,pw on middle post,switch up pw out to flasher to lite fixture. just lites up no flash. am i wiring wrong?
WEll, that is one idea, but I reccomend against it, as the brake light system is tied into the circuit, commonly. Just fix the t/s switch.
Sep 09, 2009 | 1992 Pontiac Grand Prix
I have a Great White GWB50 Runs only at one speed Can only turn it off with toggle switch. Variable speed doesn't work. Do I need a circuit board. This happened after I replaced the mount and reattached...
I have one too. Although it could be the mother board - if it runs its the potentiometer. You can get one from Iboats or Mie Reel Repair the number is AP16802. If its the mother board they are switching to digital. I havent had to go there yet. Tight lines to ya. From South Texas Riviera.
May 19, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Multiple switches/multiple amplifiers
All the amps should be wired directly to the battery, with a toggle switch on each of them. most amplifiers have a SWITCH wire as well, shich is usually wired to your ACC wire on the stereo. instead, run each SWITCH wire to a positive wire through the toggle switch. If done right, you should be able to run each amp on a separate circuit and can turn them on or off as you wish.
Oct 22, 2008 | 1986 Honda Accord
Waring WMK300 Professional Belgian Waffle Maker Logo
187 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
